I didn’t find anything about the ToF chip (GYVL53LOX) in the forum.Maybe someone should need it.
For ESP32 DEVKITV1 or other ESP32 boards.You only need to connect SDA, SCL, 5V, GND (purple square mark pin), or use any idle GPIO as 5V(blue square mark pin), set to high level (actual 3.3V), it can also drive 53LOX work.After the program runs, there will output a real-time distance value every second on the V0 virtual pin.
#include <Wire.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#define address 0x29
byte gbuf[16];
char auth[] = "your auth";
char ssid[] = "your ssid";
char pass[] = "your password";
void sendSensor()
test();
uint16_t dist = makeuint16(gbuf[11], gbuf[10]);
Blynk.virtualWrite(V0, dist);
Wire.begin();
void test() {
write_byte_data_at(0x00, 0x01);
read_block_data_at(0x14, 12);
Serial.println(dist);
uint16_t makeuint16(int lsb, int msb) {
return ((msb & 0xFF) << 8) | (lsb & 0xFF);
void write_byte_data(byte data) {
Wire.beginTransmission(address);
Wire.write(data);
Wire.endTransmission();
void write_byte_data_at(byte reg, byte data) {
Wire.write(reg);
Wire.write(data);
void read_block_data_at(byte reg, int sz) {
int i = 0;
write_byte_data(reg);
Wire.requestFrom(address, sz);
for (i = 0; i < sz; i++) {
while (Wire.available() < 1) delay(1);
gbuf[i] = Wire.read();
