Reading the Labeled Value from App to Hardware
I tried to read the Labeled Value from App to Hardware (afternoon I will paste the code).
Is it possible? becouse i receive only “0” (I am using param.asInt(Vx)).
Reading the state of the button is working fine but any “analog” value not.
Are you trying to read the label or the value?
At present, label can only be read by parsing the json project file via an API call.
I need only the value
The value of a display widget is a String, does this hlep?
