I am sending measurement data from arduino to Node.js blynk-client via serialport
float mA, Volt = 0.0f;
UART_writeFloat(Volt);
UART_writeFloat(mA);
void UART_writeFloat (float value)
const byte * p = (const byte*) &value;
for (byte i = 0; i < 4; i++)
Serial.write(*p++);
And accept in the server on Ubuntu with NodeJS. I don’t know anything about NodeJS, but the code from the example of working with the serialport receives only raw data into the buffer.
var buffer = '';
var Voltage = 0.0;
var Current = 0.0;
port.on('data', function(buffer) {
console.log(buffer);
and so I get
<Buffer 6f 83 60 40 c1 14 74 c1>
help get my sent data into two float variables Voltage and Current.
Obviously HEX. Define your data as a specific number, decode the resulting HEX and see if you can make sense of it.
6f = 111
83 = 131
60 = 96
40 = 64
c1 = 191
14 = 18
74 = 116
c1 = 193
Ohh… sorry, but I am not familiar with JS. and I did not understand anything from what you wrote …
I just need help with the code, how to load data from the buffer into a float variable.
I have problem with JS code only…
That makes two of us.
What does this function output on the serial?
Serial.write(*p++);
It output 4 bytes of float-var
I don’t know how to concat them back to float in JS
Found !!!
var vVolt = new blynk.VirtualPin(25);
var vIrms = new blynk.VirtualPin(26);
var vPWR = new blynk.VirtualPin(27);
port.on('data', function(chunk) {
Voltage = chunk.readFloatLE(0);
Current = chunk.readFloatLE(4);
Power = chunk.readFloatLE(8);
vVolt.write(Voltage);
vIrms.write(Current);
vPWR.write(Power);
