Reading data from analog pin Nodemcu
Hi guys. I’m having issues with creating the sketch for my project. I use Nodemcu v0.9 board. The code you see
#include <OneWire.h>
#define ONE_WIRE_BUS D4
char auth[] = "748236878788410da******************";
char ssid[] = "*****";
char pass[] = "*******";
  sensors.begin();
void sendTemps()
  float temp = sensors.getTempCByIndex(0);
  Serial.println(temp);
  Blynk.virtualWrite(V1, temp);
  sendTemps();
is working fine with ds18b20 sensor but I want to add an option - I would like to read data from the only analog pin on the board(A0) and send it to virtual pin. I found simillar topic in the site
http://help.blynk.cc/getting-started-library-auth-token-code-examples/blynk-basics/how-to-display-any-sensor-data-in-blynk-app ,
but I can’t handle with the code. When I try to put this
BLYNK_READ(V5) //Blynk app has something on V5
  sensorData = analogRead(A0); //reading the sensor on A0
  Blynk.virtualWrite(V5, sensorData); //sending to Blynk
in the code I receive error while verify - ‘sensorData’ was not declared in this scope.
What I have to do, how the code should look like? Thanks.
For Local Use
  int sensorData = analogRead(A0); //reading the sensor on A0
or for Global Use
int sensorData;
Still not working…Am I doing it corectly or…
char auth[] = "748236878788410da51e93e7******"
char ssid[] = "****";
  sensors.begin();
void sendTemps()
int sensorData
  sendTemps();
There is the error message:
WARNING: Spurious .github folder in 'Adafruit NeoPixel' library
In file included from C:\Users\Ralica\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:18:0,
                 from C:\Users\Ralica\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
                 from C:\Users\Ralica\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp8266.h:18,
                 from C:\Users\Ralica\Desktop\NodeMCUmode\NodeMCUmode.ino:42:
C:\Users\Ralica\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkHandlers.h:158:5: error: expected initializer before 'void'
     void BlynkWidgetRead ## pin  (BlynkReq BLYNK_UNUSED &request)
C:\Users\Ralica\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkHandlers.h:164:31: note: in expansion of macro 'BLYNK_READ_2'
 #define BLYNK_READ(pin)       BLYNK_READ_2(pin)
C:\Users\Ralica\Desktop\NodeMCUmode\NodeMCUmode.ino:87:1: note: in expansion of macro 'BLYNK_READ'
exit status 1
Error compiling for board NodeMCU 0.9 (ESP-12 Module).
You’re missing a closing curly bracket “}” at the end of your BLYNK_READ (V5) function and a semicolon “;” from the end of your sensorData variable declaration.
It’s also normal practice to declare your global variables at the top of your code (before void setup in your case).
I’m not sure that the fixed code will meet your design requirements though. You should be using a timer to take readings from your sensors and send them to Blynk. You should also include a pinmode declaration for your analogue pin to use it as an input pin.
And again I have the same - sensor data was not declared in this scope. There is the code:
char auth[] = "748236878788410da51e93e7*******";
char pass[] = "******";
void sendTemps()
int sensorData
  sensors.begin();
  sendTemps();
  timer.run(); // running timer every second
I strart to think, that there is some issue with the libraries
int sensorData;
void sendTemps()
 sensors.begin();
 timer.setInterval(1000L, sendTemps);
Or
int sensorData;
void sendTemps()
void sendAnalog()
 sensors.begin();
timer.setInterval(1003L, sendAnalog);
The difference being in the display widget settings. The first example would need the frequency set to some interval, say 3 seconds like in the example on the link you posted.
For this code the frequency would be set to push, and the interval would be set by the timer. In this case approx. every 1 second.
This is all explained in the link you posted. I suggest you re-read it any try to get a better understanding of what it is saying.
Nirvana at last!! Thank you Toro_Blanco! The last sketch is the thing I was searching for. I just flash it on the board. However it seems that I am the idiot who is not expaining what exactly need to do😁.
So I needed to insert some basic signals in the board with a simple voltage divider.
Then to set events with
the different values appearing on the virtual pin. And then swiching digital pins on and off both form the blynk app on the smartphone and with a hardware button. And if you push a hardware button the changed condition of the digital pin will appear on the smartphone app, you will receive a feedback.
That’s it. I will use it for some home automation such as central heating schedule and temperature adjust, swiching on and off mostly common used electrical appliances and other. If someone is interested I can share the hardware and the wiring needed.
If that’s your aim then I’d use a different sensor. The BME280 is my preferrred sensor, it’s digital and has the advantage of also providing Humidity and if needed Atmospheric Pressure data.
I’d also provide some sort of display that allows users to see the current and target temperature settings, and change them without having to use the app. I use a Nextion touch screen, but a small OLED display would also be an option.
You should also build-in some hysteresis code into your project, to desensitise the thermostat and prevent the heating switching on and off rapidly when the current temperature is hovering around the target temperature.
