I want to use Blynk to monitor a few things,
I have it working to
Read
4 Ds18b20’s
1 Dth11
1 voltage sensor, voltage divider to read battery voltage
I can not get the right figure for the battery sensor I get a reading of 520 from the ADC0,with a 9volt battery(going to be using a 12 volt car battery) just can’t figure out the right formula and place to put it.
My code
//working on chip 3,all Ds18b20's and the dth11 and 1 voltage sensor
//need to fine turn voltage sensor
// pin D2 is connented to 4- Ds18b20's
// pin D7 is DTH11
// Pin D6 is Led Out Button
// A0 is voltage sensor
#include <Wire.h>
//#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <OneWire.h>
//DHT sensor
#define DHTPIN 13
#define b1pin 15
#define DHTTYPE DHT11
#define VT_PIN A0
// define other voltage pin here
DHT dht(DHTPIN, DHTTYPE);
#define ONE_WIRE_BUS 4
// Assign the addresses of your 1-Wire temp sensors.
DeviceAddress Probe01 = { 0x28, 0xff, 0x40, 0x93, 0x3c, 0x04, 0x00, 0x96 }; //S1
DeviceAddress Probe02 = { 0x28, 0xff, 0x82, 0x93, 0x3c, 0x04, 0x00, 0x37 }; //S2
DeviceAddress Probe03 = { 0x28, 0xff, 0xe6, 0x70, 0x3b, 0x04, 0x00, 0x82 }; //S3
DeviceAddress Probe04 = { 0x28, 0xff, 0x8d, 0x51, 0x3a, 0x04, 0x00, 0xb7 }; //S4
//DeviceAddress Probe05 = { 0x28, 0xAB, 0x58, 0x2D, 0x17, 0x13, 0x01, 0x2B }; //S5
//Blynk token
char auth[] = "------------------------------------f";
// WiFi credentials.
//char ssid[] = "lvl1";
//char pass[] = "----------";
char ssid[] = "lockadoc";
char pass[] = "---------";
//DHT Sensor
void sendSensor()
float h = dht.readHumidity();
float t = dht.readTemperature(true);
Blynk.virtualWrite(V6, h);
Blynk.virtualWrite(V7, t);
void getTempData()
Blynk.virtualWrite(V1, sensors.getTempFByIndex(0));
Blynk.virtualWrite(V2, sensors.getTempFByIndex(1));
Blynk.virtualWrite(V3, sensors.getTempFByIndex(2));
Blynk.virtualWrite(V4, sensors.getTempFByIndex(3));
Blynk.virtualWrite(V8, sensors.getTempFByIndex(4));
// Voltage Sensor
void getVoltage()
int vt_read = analogRead(VT_PIN);
float voltage4 = vt_read * (3.2 / 1024.0) * 5.0;
Blynk.virtualWrite(V15, voltage);
//DHT Sensor
dht.begin();
//watertemp sensor
sensors.begin();
sensors.setResolution(10);
timer.setInterval(1500L, getTempData);
timer.setInterval(2000L, getVoltage); // no need to add another of these!
