Hii There
My Setup:
Arduino MKR1010
kemo rain detector m152
This rain detector is connect to my Arduino Pin A4/Ground and open/Closes a internal contact.
How can i read the state of that Pin (High/Low) and save it as a variable for later use?
Hii There
My Setup:
Arduino MKR1010
You have to adapt this to your blynk sketch
int inPin = 4;
int val = 0; // variable to store the read value
pinMode(inPin, INPUT); // sets the digital pin 4 as input
val = digitalRead(inPin); // read the input pin
This doesn’t sound like it’s a Blynk related question at all.
You’d normally connect a sensor that gives an analog output (values between 0 and 1023 for example) to an antilog pin, and digital sensors that give a HIGH/LOW output to a digital pin.
Having said that, analog pins can be make to work like digital pins if required.
You need to declare the oin as an input in your void setup, the read the value using either a digitalRead() or analogRead command.
kemo rain detector m152 has only a relay output state wire
Im sooorry, what does that mean?
Hi Blynk_Coeur
Thanks a lot for the answer
but how can i store the value 1 / high instead of 0 ?
int inPin = 4; int val = 0; // variable to store the read valu
If i use 1, i think it takes pin1 instead of value 1
@Avi1 This is a Blynk forum, not a C++ Coding 101 forum.
I’d suggest that you either ask a Blynk related question or take a crash-course in C++ coding.
val store any result 0 or 1
