Read-Only Vpins
Would like to see a possibility to mark Vpins as read-only from server side.
Example: Selector with multiple devices, and two Value Displays binded to two Vpins. I can select devices and see it’s values on that Vpins, but I can’t create another tab and place multiple “usual” Value Displays binded for each Vpin of each device, because Selector make that Vpins “busy”.
This is device selector limitation. This may be improved in future. As workaround you may just use another pin.
Okay, thank you.
