Hi friends. I want to reading a file from SD card to virtual pins (V5 in the blow sketch). for test I wrote Hello world in a text file that’s named add.txt
but when reading it from SD card, in the virtual pins shows numbers instead of letters. any idea to fix ?
here the sketch:
#define TINY_GSM_MODEM_SIM800
#define CS_PIN 15
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#include <SD.h>
char auth[] = "iPeGEj1JIvNqY32488987-hLMo8Ik3pj";
char apn[] = "mcinet";
char user[] = "";
char pass[] = "";
char server[] = "10.5.51.5";
SoftwareSerial SerialAT(5, 4);
TinyGsm modem(SerialAT);
WidgetRTC rtc;
File myFile;
String currentTime;
String currentDate;
SerialAT.begin(9600);
delay(3000);
modem.restart();
Blynk.begin(auth, modem, apn, user, pass, server, 8080);
rtc.begin();
if (!SD.begin(CS_PIN)) {
timer.setInterval(10000L, clockDisplay);
void clockDisplay()
currentTime = String(hour()) + ":" + minute() + ":" + second();
currentDate = String(day()) + "-" + month() + "-" + year();
Blynk.virtualWrite(V1, currentTime);
Blynk.virtualWrite(V2, currentDate);
Blynk.virtualWrite(V3, "Fault Detected");
Blynk.virtualWrite(V4, 100);
myFile = SD.open("add.txt", FILE_READ);
if (myFile) {
while (myFile.available())
Blynk.virtualWrite(V5, myFile.read());
myFile.close();
myFile = SD.open("faults.txt", FILE_WRITE);
if (myFile) {
myFile.println(currentTime);
myFile.println(currentDate);
myFile.println("---------------");
myFile.close();
ESP.deepSleep(0);
We’re the numbers 72 101 108 108 111 32 119 111 114 108 100 ?
I’d try putting some serial print statements in there and see what’s coming out of your file.
[27364] Connected to GPRS
[27426] Connecting to 37.245.193.215:8080
[29112] Ready (ping: 873ms).
[30136] Time sync: OK
55
hmmm. I’m edit the sketch and it worked on serial print but in app showing number 1
myFile = SD.open("add.txt");
if (myFile) {
while (myFile.available()) {
Serial.write(myFile.read());
Blynk.virtualWrite(V5, myFile);
myFile.close();
[10080] Modem init...
[11331] Connecting to network...
[27794] Network: 43235
[27794] Connecting to mtnirancell ...
[35842] Connected to GPRS
[35903] Connecting to 37.245.193.215:8080
[38326] Ready (ping: 876ms).
[39359] Time sync: OK
hello world
That’s what I’d expect.
would be the matching command to Serial.write(myFile.read());
I do that like below but nothing
if (myFile) {
myFile.close();
Maybe comment-out the Serial.write(myFile.read());
as perhaps this reading he whole of the file.
If not then maybe read the file into a variable and serial.print/virtualWrite that?
like below ? but not working
if (myFile) {
char ADD = myFile.read();
Blynk.virtualWrite(V5, ADD);
myFile.close();
khoih
June 20, 2020, 6:44am
11
You have to read the whole file into a buffer, then send the buffer to Serial or Blynk, as follows:
// Change the buffer size as necessary
#define BUF_SIZE 256
char temp_buffer[BUF_SIZE];
if (myFile)
uint16_t len = (uint16_t) myFile.size();
if (len < BUF_SIZE - 1 )
// To make sure NULL terminated
memset(temp_buffer, 0, sizeof(temp_buffer));
myFile.read((uint8_t*) temp_buffer, len);
Serial.println(temp_buffer);
Blynk.virtualWrite(V5, temp_buffer);
myFile.close();
thanks for reply. but not showing text in blynk V5. just showing number 104
here the code:
#define CS_PIN 15
#include <SD.h>
char auth[] = "iPeGEj1JIvNqY32FRPZ4x-hLMo8Ik3pj";
char apn[] = "mtnirancell";
char user[] = "";
char pass[] = "";
char server[] = "37.245.193.215";
WidgetRTC rtc;
File myFile;
String currentTime;
String currentDate;
String string;
delay(3000);
modem.restart();
rtc.begin();
void clockDisplay()
if (myFile)
myFile.close();
khoih
June 20, 2020, 7:34am
13
There is something strange, could you try again these 2 code snippets, one by one, then post the terminal output to see what’s happening
if (myFile)
Serial.println("Temp Buffer = " + String(temp_buffer));
Blynk.virtualWrite(V5, String(temp_buffer));
myFile.close();
and
if (myFile)
uint16_t pos = 0;
if (pos < BUF_SIZE)
temp_buffer[pos++] = myFile.read();
myFile.close();
the serial print and no hello world
[10616] Modem init...
[11861] Connecting to network...
[15685] Network: 43235
[15685] Connecting to mtnirancell ...
[23210] Connected to GPRS
[23271] Connecting to 37.245.193.215:8080
[26638] Ready (ping: 2378ms).
[30128] Time sync: OK
hmmm. the problem solved with below code thanks @khoih
now showing in V5
if (myFile) {
myFile.close();
[13953] Modem init...
[15201] Connecting to network...
[20155] Network: 43235
[20155] Connecting to mtnirancell ...
[27270] Connected to GPRS
[27332] Connecting to 37.245.193.215:8080
[30855] Ready (ping: 1393ms).
[31864] Time sync: OK
⸮Temp Buffer = hello world
khoih
June 20, 2020, 8:06am
16
Post too late. You’re so fast
Can you check these following items
Add Serial.begin(115200); at the beginning of setup(). Be sure the file still has hello world
and not erased yet by running your original code which showed the hello world
If OK, add the seek() before read()
if (myFile)
myFile.seek(0);
Serial.println("File size = " + String( myFile.size()));
myFile.close();
and
if (myFile)
uint16_t pos = 0;
myFile.seek(0);
myFile.seek(0);
if (pos < BUF_SIZE)
myFile.close();
If still has issue, post the terminal output again. Inform which board (ESP32??) and SD card you are using.so that we can duplicate the problem.
thanks. you saved my day I’m using ESP8266 Nodemcu with SD module and SIM800L.
I had de same problem here. I’ll try this code. Thx
