Read Analog inputs from API on local server
I setup a local server and can read digital pin state and control the digital pins fine. But I am trying to read from A0 or A1 and all I ever get is: Requested pin not exists in app. I am using A0 and A1 and the values display fine in the Blynk app on my phone. However from the API I have yet to see any Analog data.
curl --include ‘http://hostname.com:8080/myapikey/pin/A0
HTTP/1.1 400 Bad Request
Connection: keep-alive
Content-Type: text/plain
Content-Length: 32
Version: server-0.15.3.jar
Any Ideas?
Thanks…
Hello. Do you have widget with A0 selected?
Hi mikrologic,
you should try something like that:
curl --include ‘http://hostname.com:8080/myapikey/pin/A15
Else you may retrieve the proper pin number if you edit your project file in your data folder on your blynk server.
BR.
Ive just had this same problem - I got the pin number by looking at the widget from http://hostname.com:8080/myapikey/project
(or if using the blynk server http://blynk-cloud.com/myapikey/project)
My ADC0 was actually A17
