RaspberyPi JoyStick
I am using a raspberry pi and the Geany IDE to build the following Raspberry Pi sketch obtained from the Sketch builder examples,see below…
Social networks:            http://www.fb.com/blynkapp
                            http://twitter.com/blynk_app
You can receive x and y coords for joystick movement within App.
App project setup:
Two Axis Joystick on V1 in MERGE output mode.
MERGE mode means device will receive both x and y within 1 message
#define BLYNK_PRINT stdout
#ifdef RASPBERRY
#include <BlynkApiWiringPi.h>
#else
#include <BlynkApiLinux.h>
#endif
#include <BlynkSocket.h>
#include <BlynkOptionsParser.h>
static BlynkTransportSocket _blynkTransport;
BlynkSocket Blynk(_blynkTransport);
#include <BlynkWidgets.h>
BLYNK_WRITE(V1) {
int x = param[0].asInt();
int y = param[1].asInt();
// Do something with x and y
Serial.print("X = “);
Serial.print(x);
Serial.print(”; Y = ");
Serial.println(y);
int main(int argc, char* argv[])
const char *auth, *serv;
uint16_t port;
parse_options(argc, argv, auth, serv, port);
Blynk.begin(auth, serv, port);
setup();
while(true) {
loop();
return 0;
Please take a look at your post.
Terrible formatting, search the site on how to post a formatted sketch.
No question, do you think we are mind readers?
Sorry for the previous crappy post.
I am using a raspberry pi and the Geany IDE to build the following Raspberry Pi sketch obtained from the Sketch builder examples,see below.
When I try to build it the error message says cannot find BlynkApiWiringPi.
The project was placed however it the Blynk library where this “missing” file is located.
Any idea?
Thank you,
Dan
Take a look at this thread Using C++ on a Raspberry Pi with Blynk
Thank you, from the link you suggested I was able to read the joystick and display the results on my pi screen.
How would I modify the code in the link to get pwm to work on the pi?
So far,I’ve used the commands pinMode(1,PWM_OUTPUT) and pwmWrite(1,255) to output the pwm to pin1, gpio 18, on the pi to control an LED without luck, it did not light.
@FizixDan we don’t use PWM as for us something is either on or off.
I suspect you know more than us about PWM and presumably you are familiar with Gordon (GPIO god) Henderson’s Software PWM for the PI at https://projects.drogon.net/raspberry-pi/wiringpi/software-pwm-library/
The following will pulse an LED from off, to full on and back down to off in a continuous loop.
#include <wiringPi.h>
#include <softPwm.h>
int bright;
int main (void)
wiringPiSetup () ;
softPwmCreate (7,0,100) ;  // wiringPi 7 (BCM 4) start at 0, maximum 100%
  for (;;)
    for (bright = 0 ; bright < 30 ; ++bright)
      softPwmWrite (7, bright) ;
      delay (50) ;
    for (bright = 29 ; bright >= 0 ; --bright)
      delay (50) ;
Note even though this will pulse an LED from off to on it doesn’t cover the full pwm range. You would need to increase the 2 entries of 30 for this but it’s not required for an LED.
As a standalone test this can be compiled with:
cc -o myprog myprog.c -lwiringPi -lpthread
and run as:
./myprog
-lwiringPi and -lpthread are covered when you use the build.sh script for Blynk so with a bit of effort you should be able to get something working with Blynk and Pi using C++.
