Hi
I am programming a raspberry Pi but there is a bug in my program but I can’t fix it. The bug is that when I press V2 in the app the relais works but I also get a notification. Could someone please take a look at my program and maybe you can see the fault.
Thanks in advance!
var Blynk = require('/usr/local/lib/node_modules/blynk-library');
var AUTH = 'b6216e4b56964600ba05xxxxxx';
var blynk = new Blynk.Blynk(AUTH);
const Gpio = require('onoff').Gpio;
const schakelaar = new Gpio(2, 'in', 'both'); //schakelaar deksel
const relais = new Gpio(7, 'out'); //relais solenoid
const IR = new Gpio(3, 'in', 'both'); //IR sensor
const bel = new Gpio(6, 'in', 'both'); //Drukknop bellen
const LED = new blynk.VirtualPin(5);
const EN = new Gpio(5, 'out');
var v2 = new blynk.VirtualPin(2);
EN .writeSync(1)
schakelaar.watch((err, value) => {
if (err) {
throw err;
if (value == 0) {blynk.notify("open");}
console.log('value is:', value);
process.on('SIGINT', () => {
schakelaar.unexport();
v2.on('write', function() {
if(relais.readSync() == 0) {
relais.writeSync(1);
else {
relais.writeSync(0);
bel.watch((err, value) => {
if (err) {
throw err;
if (value == 0) {blynk.notify("test");}
bel.unexport();
IR.watch((err, value) => {
if (err) {
throw err;
if (value == 0) {blynk.notify("geplaatst");}
IR.unexport();
if (value == 0) {blynk.virtualWrite(5, 255);
else {
blynk.virtualWrite(5, 0);
