siva
1
Error: connect ECONNREFUSED 188.166.206.43:8441
at Object._errnoException (util.js:1022:11)
at _exceptionWithHostPort (util.js:1044:20)
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1198:14)
code: ‘ECONNREFUSED’,
errno: ‘ECONNREFUSED’,
syscall: ‘connect’,
address: ‘188.166.206.43’,
port: 8441 }
i tried everything even changed the port. i need help. step by step solution would be helpful. i did not face this problem a week ago.
Gunner
2
How about a search suggestion
such as searching just the last day or two of similar issues due to using old ports like 8441.
Keeping up with the announcements is also highly recommended
https://community.blynk.cc/search?q=Local%20Server%20port%20%23announcements%20order%3Alatest
siva
3
i do not know how to change the port to 443. please explain the steps.
Gunner
4
I guess that depends on the library used… WiringPi, NodeJS or Python
