Hey, for a project I am working on I require an interrupt to triggered on one of my pins for the raspberry P 3 B+. I have been able to get everything working except for the attachInterrupt function. When I build the project I get:
main.cpp:65:3: error: ‘attachInterrupt’ was not declared in this scope
attachInterrupt(digitalPinToInterrupt(2), checkPin, CHANGE);
I am running the example code given at: https://examples.blynk.cc/?board=Raspberry%20Pi&shield=System%20default&example=More%2FSync%2FButtonInterrupt
Shown Below.
Any help or tips as to why this wont build would be greatly appreciated.
http://twitter.com/blynk_app
This example shows how to monitor a button state
using interrupts mechanism.
App project setup:
LED widget on V1
#define BLYNK_PRINT stdout
#ifdef RASPBERRY
#include <BlynkApiWiringPi.h>
#else
#include <BlynkApiLinux.h>
#endif
#include <BlynkSocket.h>
#include <BlynkOptionsParser.h>
static BlynkTransportSocket _blynkTransport;
BlynkSocket Blynk(_blynkTransport);
#include <BlynkWidgets.h>
WidgetLED led1(V1);
// We make these values volatile, as they are used in interrupt context
volatile bool pinChanged = false;
volatile int pinValue = 0;
// Most boards won't send data to WiFi out of interrupt handler.
// We just store the value and process it in the main loop.
void checkPin()
// Invert state, since button is "Active LOW"
pinValue = !digitalRead(2);
// Mark pin value changed
pinChanged = true;
// Make pin 2 HIGH by default
pinMode(2, INPUT_PULLUP);
// Attach INT to our handler
if (pinChanged) {
// Process the value
if (pinValue) {
led1.on();
led1.off();
// Clear the mark, as we have processed the value
pinChanged = false;
int main(int argc, char* argv[])
const char *auth, *serv;
uint16_t port;
parse_options(argc, argv, auth, serv, port);
Blynk.begin(auth, serv, port);
setup();
while(true) {
loop();
return 0;
