my knowledge in the Linux world limited , i have tried to run a local server on RPI 3 running latest RASPBIAN JESSIE WITH PIXEL.
i have followed the provided guide to start Blynk server on Boot , but no success.
i have repeated the steps more than once and make sure that it’s OK , am i missing something or there is a difference because of the latest update of rasbian?
Put it in init.d. It’s the only good solution and widely accepted. Be sure to use a delay in your startup script. If you put it in the correct init.d, it should be very stable. Crontab is more for timed things (like simpletimer). Init.d is the place to put startup scripts.
Can you indicate what you did to make it run at start up? Maybe you followed a certain webpage? I can take a look at it
init.d has eveolved on the Debian platform and works really well. Usually it’s some sort of weird script error or putting things on the wrong runlevel, bad software or such which screws up the process.
i have tried to edit rc.local and add java -jar /home/pi/server-0.18.3.jar -dataFolder /home/pi/Blynk &
but i am getting access denied and i logged in using the root user
edit : i have changed it using other editor with root access but after restart not working
That’s not really the right procedure. First off, it’s alway recommended to make a startup script. There is one on the forum here (which I provided). You can place that in your Blynk directory and add the script to init.d. You cannot simply add a line to rc.local. You have to tell it to add the script.
