Quick Menu
I’d love the option to have a quick menu. I’ve seen them in other apps and thought it would be handy here.
A quick menu is one that you can slide vertically or horizontally using a single swipe to change the menu item. This is instead of the current 3 gesture menu.
In fact it would be cool if the normal menus were just like that.
Hi, thanks!
Could you send an example? Screenshot? I’m not sure I understand.
Hmm couldnt find any examples… but imagine a Menu… but instead of clicking on it, then selecting the item from a list and pressing okay… you simply have the widget with arrows pointing left and right and you swipe the widget to change between the items.
Obviously getting from item 1 to item 4 means you have to swipe past 2 and 3… so you would put in a slight delay before it sends the WRITE command to the hardware so it knows for certain which item you meant to choose. Or maybe when you stop swiping you have to tap the widget to confirm.
