Quick button to zoom out Map to "default" or whole continent / side of planet size
When a new pin is added, the map is supposed to make sure that all pins (including newly added) are visible to the user. So,
  • if current position/scale are good enough, nothing changed
  • try just changing position (without affecting zoom) to make all pins visible
  • at last, change position and zoom to make all pins visible
Sounds like you do syncing virtual pins on conecting to server in your skecth…
