Dear Sirs,
is there an easy on demand way to do what the command ex
setSyncInterval(60);
does?
For the needs of my project I need to “manual activate/initiate” this sync on demand regardless of the above command.
Thanks a lot for your answer but I am not sure that I understood.
I want to be able to synchronize the time on my ESP8266 ( the time is getting from NTP server ).
Because I am writing my own routine for auto timezone adjustment ( DST … ) I need a way when I calculate the correct timezone then to synchronize the time getting the new timezone in to consideration. That’s why I need a manual way to initiate something like setSyncInterval(now) .
That is!
P.S. I don’t want to use blynk RTC and TimeInput timezone for some reasons
Why don’t you want to use those libraries? They work perfectly fine, even with DST.
I’ve made a routine which checks if the year is 1970 and sets a low value on syncInterval and if the year is no longer 1970, it sets a longer interval to prevent flooding and such. Maybe you can apply some of that logic with a flag that you can set to initiate a short interval? E.g. if flag0 = 1, setSyncinterval(lowvalue) otherwise, set it to 300 or something.
thanks a lot for your answer. I have done this in a similar way.
I develop a project that can be work without blynk and for this reason I am looking for a sane way to initiate re-sync without changing the setSyncInterval(nn) nn value.
I tried to see/follow how TimeLib implement this sync in order to gain access to the particular function that does the actual sync ( because the logic says that check the nn time and when it is passed a function call back will be performed ) but without success, I am not good in C / C++.
Anyway, again I thank you for your nice suggestion.
To answer my question, see:
A fine way to achieve the requested above ( as Mr, blackketter suggested me @ https://github.com/PaulStoffregen/Time/issues/60 ), just a call to setSyncProvider() with our time function, initiate the sync line “syncNow”… In my case, just a call to: setSyncProvider(getNtpTime);
do the trick.
Problem solved!
Thanks very much for reporting back with this! I myself can use it, lol.
I made a little variation on the theme I suggested. This day and age I set a very low value for interval in Setup(). Then with a timer I check if the year does not equal 1970 anymore and then I set the interval much bigger. Also works fine
Dear friend,
Just keep in mind that time lib also provide a way to tell you if there is correct time or not, just try something like:
timeStatus() == timeNotSet
