QR code failed to generate
@Dmytro @BlynkAndroidDev , i have added 25 devices to my app ( maximum device for my app ) , when i tried to share the app , the QR code failed to generate and the sharing link also not created in the sharing text message ( looks no link on the text messages ) and i planned to reduce the device to 10 number , the QR code generated but it is not scannable by other devices ( looks very compact ) . i have attached the images below for your references
(devices = 30)
. ( devices = 10 )
Are you on a local server?
yes , i am using my local server
There would be no such issue on Blynk Cloud. On a local server we have two ways of project clone - one via saving the project to the QR (this is your case), if there are not a lot of widgets, and same as on Blynk Cloud - cloning via clone-token. In the next release I’ll add an additional check that will switch your case to token clone logic.
