Hello… I have a code that worked on the old blink … on blink 2.0 it does not want to show data … help maybe I do not understand something … tried different options .
blynk library vesion 1.0.0
PZEM-004
Esp32
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME ""
char auth[] = "";
#include <PZEM004T.h>
#define APP_DEBUG
#include "BlynkEdgent.h"
PZEM004T pzem(&Serial); /// use Serial
IPAddress ip(192,168,1,4);
float voltage_blynk=0;
float current_blynk=0;
float power_blynk=0;
float energy_blynk=0;
unsigned long lastMillis = 0;
delay(100);
Blynk.begin(auth, "dd-wrt", "11111111");
BlynkEdgent.begin();
pzem.setAddress(ip);
BlynkEdgent.run();
float v = pzem.voltage(ip);
if(v >= 0.0){ voltage_blynk =v; } //V
float i = pzem.current(ip);
if(i >= 0.0){ current_blynk=i; } //A
float p = pzem.power(ip);
if(p >= 0.0){power_blynk=p; } //kW
float e = pzem.energy(ip);
if(e >= 0.0){ energy_blynk =e; } ///kWh
if (millis() - lastMillis > 10000) {
lastMillis = millis();
Blynk.virtualWrite(V21, voltage_blynk);
Blynk.virtualWrite(V22, current_blynk );
Blynk.virtualWrite(V23, power_blynk);
Blynk.virtualWrite(V24, energy_blynk );
Blynk.virtualWrite(V25, lastMillis );
@Taras_Yurychko please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
You also need to provide the requested information about library version, app version, hardware etc.
tried on esp8266 … does not work//
help ////
How have you defined the datastreams for V21 to V25, especially the Data Types and the Min/Max values?
Also, you really need to sort-out your void loop and replace the delay with a timer…
thanks corrected but still does not work … to check installed the old version and it works …
Data Types in double
#define APP_DEBUG
IPAddress ip(192,168,1,49);
int voltage_blynk=0;
delay(100);
timer.setInterval(1000, pz);
void pz(){
BlynkEdgent.run();
Why do you have this code still?
What about your datastream min/max settings?
hello… now running thanks …
char auth[] = "";
#define APP_DEBUG
#include <HardwareSerial.h>
// hwserial UART2 at pins IO-16 (RX2) and IO-17 (TX2)
HardwareSerial PzemSerial2(2); // Use hwserial UART2 at pins IO-16 (RX2) and IO-17 (TX2)
PZEM004T pzem(&PzemSerial2); /// use Serial
IPAddress ip(192,168,1,1);
delay(100);
void bacaPZEM(){
//PZEM
void sendtoblynk(){
bacaPZEM();
sendtoblynk();
BlynkEdgent.run();
So you’ve abandoned the clean void loop approach and gone back to blocking delays.
At some point in future you’ll wonder why you’re getting disconnections from the Blynk server, or your device is locking-up. This will be the reason why.
hello sorry forgot … now good ?
#define APP_DEBUG
#include <pzem.h>
void bacaPZEM(){
//PZEM
void sendtoblynk(){
delay(100);
timer.setInterval(10000L, sendtoblynk);
bacaPZEM();
BlynkEdgent.run();
sorry look again i’m just learning
I’d suggest that you re-read the “keep your void loop clean” document.
If your intention is to take a PZEM reading every x seconds, then upload the results to Blynk then you have two options about how to structure your code…
Put the code that reads the PZEM into a function called with a timer, and at the end of that function, call the function that sends the data to Blynk.
Put both the PZEM reading code, and the Blynk upload code into the same function and call it with a timer.
If you want different frequencies for taking PZEM readings and uploading the results to Blynk then have two separate functions, and call them with two different timers.
