PZEM-016 with NodeMCU
I’m trying to create the project for PZEM-016 with NodeMCU but getting this error when compile:
no matching function for call to 'SoftwareSerial::SoftwareSerial(const uint8_t&, const uint8_t&, bool, int)'
Please help to identify the problems
#include "settings.h"
#include "secret.h"
#include <ArduinoOTA.h>
#include <ModbusMaster.h>
#include <SoftwareSerial.h>  //  ( NODEMCU ESP8266 )
#define MAX485_DE      D1
#define MAX485_RE_NEG  D2
SoftwareSerial pzem(D5, D6, false,256);
ModbusMaster node;
double voltage_usage, current_usage, active_power, active_energy, frequency, power_factor, over_power_alarm;
uint8_t result;  uint16_t data[6];
void preTransmission()
  digitalWrite(MAX485_RE_NEG, 1);
  digitalWrite(MAX485_DE, 1);
void postTransmission()
  digitalWrite(MAX485_RE_NEG, 0);
  digitalWrite(MAX485_DE, 0);
  pinMode(MAX485_RE_NEG, OUTPUT);
  pinMode(MAX485_DE, OUTPUT);
  // Init in receive mode
  pzem.begin(9600);
  // Modbus slave ID 1
  node.begin(1, pzem);
  // Callbacks allow us to configure the RS485 transceiver correctly
  node.preTransmission(preTransmission);
  node.postTransmission(postTransmission);
#if defined(USE_LOCAL_SERVER)
  Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS, SERVER, PORT);
#else
  Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS);
#endif
  ArduinoOTA.setHostname(OTA_HOSTNAME);
  ArduinoOTA.begin();
timer.setInterval(10000L, sendtoBlynk); // send values blynk server every 10 sec
void sendtoBlynk() {
  Blynk.virtualWrite(vPIN_VOLTAGE,               voltage_usage);
  Blynk.virtualWrite(vPIN_CURRENT_USAGE,         current_usage);
  Blynk.virtualWrite(vPIN_ACTIVE_POWER,          active_power);
  Blynk.virtualWrite(vPIN_ACTIVE_ENERGY,         active_energy);
  Blynk.virtualWrite(vPIN_FREQUENCY,             frequency);
  Blynk.virtualWrite(vPIN_POWER_FACTOR,          power_factor);
  Blynk.virtualWrite(vPIN_OVER_POWER_ALARM,      over_power_alarm);
void pzemdata(){
    //node.clearResponseBuffer();
    ESP.wdtDisable();
    result = node.readInputRegisters(0x0000, 10);
    ESP.wdtEnable(1);
    if (result == node.ku8MBSuccess)
    voltage_usage      = (node.getResponseBuffer(0x00) / 10.0f);
    current_usage      = (node.getResponseBuffer(0x01) / 1000.000f);
    active_power       = (node.getResponseBuffer(0x03) / 10.0f);
    active_energy      = (node.getResponseBuffer(0x05) / 1000.0f);
    frequency          = (node.getResponseBuffer(0x07) / 10.0f);
    power_factor       = (node.getResponseBuffer(0x08) / 100.0f);
    over_power_alarm   = (node.getResponseBuffer(0x09));
  Serial.print("VOLTAGE:           ");   Serial.println(voltage_usage);   // V
  Serial.print("CURRENT_USAGE:     ");   Serial.println(current_usage, 3);  //  A
  Serial.print("ACTIVE_POWER:      ");   Serial.println(active_power);   //  W
  Serial.print("ACTIVE_ENERGY:     ");   Serial.println(active_energy, 3);  // kWh
  Serial.print("FREQUENCY:         ");   Serial.println(frequency);    // Hz
  Serial.print("POWER_FACTOR:      ");   Serial.println(power_factor);
  Serial.print("OVER_POWER_ALARM:  ");   Serial.println(over_power_alarm, 0);
  Serial.println("====================================================");
    else{
      Serial.println("Failed to read Modbus");
  ArduinoOTA.handle();
  pzemdata();
Your syntax is all wrong.
You need to declare the softwareserial pzem object initially like this:
SoftwareSerial pzem;
then in void setup() you need to do a pzem.begin(); which specifies the settings you wish to use, something like this:
pzem.begin(9600, SWSERIAL_8N1, D5, D6);
After some change on the SoftwareSerial, I was able to complied but the there is no reading on the Serial Monitor :frowning:
