Push buttons no longer highlight status
I recently made some tweaks to a Blynk-controlled sketch. I compiled with the latest library and updated the app on my iPhone. Since then, I’ve noticed that the push buttons have stopped indicating status. If I press a button, the action I’m trying to trigger will go, and the Blynk LCD will print the updated status, but the buttons don’t change. ON is no longer highlighted after pressing the button.
Is this a bug in the latest library or app update or did I break button behavior when I revised my sketch?
In my experience, a bug in a Blynk library is the last thing to expect.
But if you don’t post your sketch, how will anyone ever be able to know?
Thanks for your response, Dave.
I’m pretty sure it’s not my sketch that’s the problem now. I found an earlier version of it to try and the button behavior is still broken. I’m thinking next I’ll try rolling back the library to older versions and see if the correct behavior returns.
Below is this earlier, simpler sketch. I’m using it to control an LED cloud using Blynk.
#include "States.h"
// Debug to Blynk Serial
#if DEBUG
#endif
// Pin definitions
#define LED_PIN           V5
#define WEATHER_BTN_PIN   V0
#define WEATHER_LED_PIN   V0
#define RGB_BTN_PIN       V2
#define RGB_LED_PIN       V2
#define DISCO_BTN_PIN     V4
#define DISCO_LED_PIN     V4
#define ZERGBA_PIN        V8
#define LCD_PIN           V16
// WiFi parameters
const char WIFI_SSID[] = "-----";
const char WIFI_PSK[] = "----";
const char BLYNK_AUTH[] = "----";
// Other constants
const byte SERIAL_SOF = 0xA5;
const byte SERIAL_EOF = 0x5A;
const int OUT_BUF_MAX = 7;         // bytes
const byte COMM_RGB = 1;
const byte COMM_DISCO = 2;
const byte COMM_BLUE_SKY = 3;
const byte COMM_NIGHT = 4;
const byte COMM_OVERCAST = 5;
const byte COMM_GOLDEN = 6;
const byte COMM_SNOW = 7;
const byte COMM_LIGHTNING = 8;
// Location data (Niwot, CO)
const float LATITUDE = 40.090554;
const float LONGITUDE = -105.184861;
// Remote site information
const char http_site[] = "api.openweathermap.org";
const int http_port = 80;
// Other constants
const int TIMEOUT = 300;    // ms
const int BUFFER_SIZE = 22; // bytes
const int ICON_SIZE = 4;    // bytes
const int DT_SIZE = 12;     // bytes
// Global variables
WidgetLED weather_led(WEATHER_LED_PIN);
WidgetLED rgb_led(RGB_LED_PIN);
WidgetLED disco_led(DISCO_LED_PIN);
WidgetLCD lcd(LCD_PIN);
CloudState cloud_state;
WiFiClient client;
WeatherType current_weather;
unsigned long timestamp;
bool force_update;
uint8_t color_r;
uint8_t color_g;
uint8_t color_b;
byte out_msg[OUT_BUF_MAX];
 * Setup
  uint8_t led = 0;
  // Set up status LED
  pinMode(LED_PIN, OUTPUT);
  // Set up debug serial console
  // Start Blynk and wait for connection
  Blynk.begin(BLYNK_AUTH, WIFI_SSID, WIFI_PSK);
  while ( Blynk.connect() == false ) {
    led ^= 0x01;
    digitalWrite(LED_PIN, led);
    delay(200);
  digitalWrite(LED_PIN, HIGH);
  // Define initial state
  cloud_state = CLOUD_WEATHER;
  setLEDs();
  timestamp = millis();
  force_update == false;
  color_r = 0;
  color_g = 0;
  color_b = 0;
  lcd.clear();
 * Loop
  // Perform LED functions
  switch ( cloud_state ) {
    // Reflect weather data in clouds
    case CLOUD_WEATHER:
      doWeather();
      break;
    case CLOUD_RGB:
    case CLOUD_DISCO:
    default:
      break;
 * Blynk Callbacks
// Callback when weather button is pushed
BLYNK_WRITE(WEATHER_BTN_PIN) {
  if ( (param.asInt() == 1) && (cloud_state != CLOUD_WEATHER) ) {
    setLEDs();
    force_update = true;
// Callback when RGB button is pushed
BLYNK_WRITE(RGB_BTN_PIN) {
  if ( (param.asInt() == 1) && (cloud_state != CLOUD_RGB) ) {
    cloud_state = CLOUD_RGB;
    setLEDs();
    sendRGB();
// Callback when Disco button is pushed
BLYNK_WRITE(DISCO_BTN_PIN) {
  if ( (param.asInt() == 1) && (cloud_state != CLOUD_DISCO) ) {
    cloud_state = CLOUD_DISCO;
    setLEDs();
    sendDisco();
// Callback when the ZeRGBa changes
BLYNK_WRITE(ZERGBA_PIN) {
  color_r = param[0].asInt();
  color_g = param[1].asInt();
  color_b = param[2].asInt();
  if ( cloud_state == CLOUD_RGB ) {
    sendRGB();
// Set app LEDs
void setLEDs() {
  // Turn them all off
  weather_led.off();
  rgb_led.off();
  disco_led.off();
  lcd.clear();
  // Only turn on the one we want
    case CLOUD_WEATHER:
      weather_led.on();
      lcd.print(0, 0, "WEATHER");
      break;
    case CLOUD_RGB:
      rgb_led.on();
      lcd.print(0, 0, "RGB");
      break;
    case CLOUD_DISCO:
      disco_led.on();
      lcd.print(0, 0, "DISCO");
      break;
    default:
      break;
 * Send Modes to Pro Mini
// Send RGB code with red, green, blue values
void sendRGB() {
  out_msg[0] = COMM_RGB;
  out_msg[1] = color_r;
  out_msg[2] = color_g;
  out_msg[3] = color_b;
  transmitMessage(out_msg, 4);
// Send Disco code
void sendDisco() {
  out_msg[0] = COMM_DISCO;
 * Weather Functions
// Every 30 seconds, pull weather data and update LEDs
void doWeather() {
  // Only update every 30 seconds
  if ( ((millis() - timestamp) >= 30000) || force_update ) {
    force_update = false;
    lcd.clear();
    // Get weather data
    current_weather = getWeather();
    // Display weather on clouds
    switch ( current_weather ) {
      // Cannot get weather data
      case WEATHER_ERROR:
        lcd.print(0, 1, "ERROR");
        break;
      // Clear skies (day)
      case WEATHER_BLUE_SKY:
        lcd.print(0, 1, "BLUE SKY");
        out_msg[0] = COMM_BLUE_SKY;
        break;
      // Clear skies (night)
      case WEATHER_NIGHT:
        lcd.print(0, 1, "NIGHT");
        out_msg[0] = COMM_NIGHT;
        break;
      // Lots of clouds
      case WEATHER_OVERCAST:
        lcd.print(0, 1, "OVERCAST");
        out_msg[0] = COMM_OVERCAST;
        break;
      // Dawn or dusk
      case WEATHER_GOLDEN:
        lcd.print(0, 1, "GOLDEN");
        out_msg[0] = COMM_GOLDEN;
        break;
      // It's snowing!
      case WEATHER_SNOW:
        lcd.print(0, 1, "SNOW");
        out_msg[0] = COMM_SNOW;
        break;
      // Storm
      case WEATHER_LIGHTNING:
        lcd.print(0, 1, "STORM");
        out_msg[0] = COMM_LIGHTNING;
        break;
      // Unknown weather type
      case WEATHER_UNKNOWN:
      default:
        lcd.print(0, 1, "UNKNOWN");
        break;
// Perform an HTTP GET request to openweathermap.org
WeatherType getWeather() {
  unsigned long time = millis();
  unsigned long dt = 0;
  unsigned long sunrise = 0;
  unsigned long sunset = 0;
  char buf[BUFFER_SIZE];
  char icon[ICON_SIZE];
  char dt_str[DT_SIZE];
  char c;
  char* dummy;
  bool golden = false;
  ParserState parser_state = PARSER_START;
  WeatherType condition = WEATHER_UNKNOWN;
  // Flush read buffer
  if ( client.available() ) {
    client.read();
  // Set string buffers to null
  memset(icon, 0, ICON_SIZE);
  memset(dt_str, 0, DT_SIZE);
  // Attempt to make a connection to the remote server
  if ( !client.connect(http_site, http_port) ) {
    return WEATHER_ERROR;
  // Construct HTTP GET request
  String cmd = "GET /data/2.5/weather?lat=";
  cmd += String(LATITUDE);
  cmd += "&lon=";
  cmd += String(LONGITUDE);
  cmd += "&appid=677a825ac1f8b2b0ae519a69fbb09e92";
  //This is my personal API, you can get your own at https://home.openweathermap.org/users/sign_up
  cmd += " HTTP/1.1\nHost: ";
  cmd += http_site;
  cmd += "\nConnection: close\n\n";
  // Send out GET request to site
  client.print(cmd);
  // Parse data
  while ( (millis() - time) < TIMEOUT ) {
    // Get web page data and push to window buffer
      c = client.read();
      pushOnBuffer(c, buf, BUFFER_SIZE);
      time = millis();
    // Depending on the state of the parser, look for string
    switch ( parser_state ) {
      case PARSER_START:
        if ( memcmp(buf, "\"weather\":", 10) == 0 ) {
          parser_state = PARSER_WEATHER;
        break;
      case PARSER_WEATHER:
        if ( memcmp(buf, "\"icon\":\"", 8) == 0 ) {
          parser_state = PARSER_DT;
          memcpy(icon, buf + 8, 3);
        break;
      case PARSER_DT:
        if ( memcmp(buf, "\"dt\":", 5) == 0 ) {
          parser_state = PARSER_SUNRISE;
          memcpy(dt_str, buf + 5, 10); // This assumes 10 digits!
          dt = strtol(dt_str, &dummy, 10);
        break;
      case PARSER_SUNRISE:
        if ( memcmp(buf, "\"sunrise\":", 10) == 0 ) {
          parser_state = PARSER_SUNSET;
          memcpy(dt_str, buf + 10, 10); // Assumes 10 digits!
          sunrise = strtol(dt_str, &dummy, 10);
        break;
        case PARSER_SUNSET:
        if ( memcmp(buf, "\"sunset\":", 9) == 0 ) {
          memcpy(dt_str, buf + 9, 10); // Assumes 10 digits!
          sunset = strtol(dt_str, &dummy, 10);
        break;
      default:
        break;
  // Make sure we have a legitimate icon and times
  if ( (strcmp(icon, "") == 0) || (dt == 0) ||
        (sunrise == 0) || (sunset == 0) ) {
  // See if we are in the golden hour
  if ( ((dt - sunrise) >= 0) && ((dt - sunrise) <= 1800) ) {
    golden = true;
  if ( ((sunset - dt) >= 0) && ((sunset - dt) <= 1800) ) {
    golden = true;
  // Lookup what to display based on icon
  // http://openweathermap.org/weather-conditions
  if ( (strcmp(icon, "01d") == 0) ||
        (strcmp(icon, "02d") == 0) ) {
    if ( golden ) {
      return WEATHER_GOLDEN;
      return WEATHER_BLUE_SKY;
  } else if ( (strcmp(icon, "01n") == 0) ||
              (strcmp(icon, "02n") == 0) ) {
    if ( golden ) {
      return WEATHER_NIGHT;
  } else if ( (strcmp(icon, "03d") == 0) ||
              (strcmp(icon, "03n") == 0) ||
              (strcmp(icon, "04d") == 0) ||
              (strcmp(icon, "04n") == 0) ||
              (strcmp(icon, "09d") == 0) ||
              (strcmp(icon, "09n") == 0) ||
              (strcmp(icon, "10d") == 0) ||
              (strcmp(icon, "10n") == 0) ) {
    return WEATHER_OVERCAST;
  } else if ( (strcmp(icon, "11d") == 0) ||
              (strcmp(icon, "11n") == 0) ) {
    return WEATHER_LIGHTNING;
  } else if ( (strcmp(icon, "13d") == 0) ||
              (strcmp(icon, "13n") == 0) ) {
    return WEATHER_SNOW;
  } else if ( (strcmp(icon, "50d") == 0) ||
              (strcmp(icon, "50n") == 0) ) {
    return WEATHER_UNKNOWN;
// Shift buffer to the left by 1 and append new char at end
void pushOnBuffer(char c, char *buf, uint8_t len) {
  for ( uint8_t i = 0; i < len - 1; i++ ) {
    buf[i] = buf[i + 1];
  buf[len - 1] = c;
 * Transmitter
void transmitMessage(byte msg[], uint8_t len) {
  int i;
  byte cs;
  byte *out_buf;
  uint8_t buf_size;
  // If message is greater than max size, only xmit max bytes
  if ( len > OUT_BUF_MAX ) {
    len = OUT_BUF_MAX;
  // Full buffer is message + SOF, EOF bytes
  buf_size = len + 2;
  // Create the output buffer with BEGIN, SOF, CS, and EOF
  out_buf = (byte*)malloc(buf_size * sizeof(byte));
  out_buf[0] = SERIAL_SOF;
  memcpy(out_buf + 1, msg, len);
  out_buf[buf_size - 1] = SERIAL_EOF;
  // Transmit buffer
  for ( i = 0; i < buf_size; i++ ) {
    Serial.write(out_buf[i]);
  // Free some memory
  free(out_buf);
I uploaded the sketch after compiling with an older Blynk library and the push buttons still don’t work like they used to. This leads me to believe that the fault lies with the iOS app. I hope this bug gets addressed soon.
@Dmitriy is this a bug?
@bennyboym Do you mean that both label (e.g. “ON”) and color highlighting do not appear when you press the button?
Also please recheck you have correct settings (e.g. low value to 0 and and hight value to 1) set in you button.
That is exactly right, Eugene. When I tap a push button, the intended task gets activated, but the button circle does not fill with color and the label continues to read “OFF”. The buttons are all set with 0 for low value and 1 for high value as you said.
Hey, I see you have both WEATHER_BTN_PIN and WEATHER_LED_PIN assigned to V0
When pressing a button, the BLYNK_WRITE(WEATHER_BTN_PIN) is triggered, then setLEDs() is triggered, then weather_led.off() is triggered which sets the pin value to 0. Since this is the pin button is assigned, it immediately pushes new value to the application.
That’s insightful, Eugene. Unfortunately re-assigning the LED pins doesn’t make any difference to the behavior of my Blynk app. The buttons still aren’t highlighting like they used to.
Can you suggest anything else in the sketch that might be a culprit?
Am I really the only one having this problem?
One way to find out is to start simple… create a basic project with a button that does something simple (no feedback for now). Then press the button and watch it’s behavior. If it “highlights”, then the issue might be in your other script, if it doesn’t “highlight” then we take it from there.
