Pull up values from a device
I am using two device (2 nodemcu’s) and they are connected to one app. I want to pull up some virtual pin readings from device 1 and use those readings in device 2. Is it possible if i could do that.
Definitely possible. You will need the Bridge Widget. Check for information in the DOCS, and some example code in the Sketch Builder. If you run into trouble I am sure the community can help.
You can also do that via webhooks. But it will be more complex than bridge :slight_smile:
Thanks alot
thanks…i will try bridge widget first and then will see web hooks. Thanks for your reply
