[Project Settings] SEND APP CONNECTED COMMAND
I didn’t find what’s the use of this new option… ?
It tells you when your Smartphone opens and closes the Blynk app.
Hi @Costas ,
How do you get the ‘app connected’ status on your device?
couldn’t find documentation for this.
i would like to control a device through a sensor, unless the app is connected - and then the wifget overrides the sensor.
is this possible?
thanks,
Elad
I think it is a new feature that is still getting tested? No mention of it in Docs yet, that I can find.
https://github.com/blynkkk/blynk-library/blob/master/examples/More/AppConnectedEvents/AppConnectedEvents.ino
It works fine. But requires the latest lib from the github master.
Outstanding issues BLYNK_APP_CONNECTED () {} doesn't work. · Issue #313 · blynkkk/blynk-library · GitHub and Re-test APP_CONNECTED, RTC, linux and BlynkTimer · Issue #334 · blynkkk/blynk-library · GitHub
