Good Morning.
I’ve already have a product launch to the industrial market , that using BLE, WIFI & Etc to made API for integrations.
Now, some clients want’s to using also cloud. So I think to use blynk as server place.
The problem I found is regard with the “bloking” calls. All the softwre is alredy done (severall thousand of code) using noy bloking methods (Because sensors must be read every second). The problem I have is to use Blynk in the main stream of the program because, even if I use config instead begin, the connect and also the run is a bloking procedure.
My question is: For now I’ll check to using blink on a secondary thread over core 0 of ESP32, but in the future I want move to completely non blocking operations. Do you have any description of the protocol using against the server to implement myself in non bloking way? Of course I can check against the library but I’t will take a lot of time. to do, so maybe to know the protocol speed up all the procedure.
Thanks a lot
Jorge Ignacio Contreras Ramire from “DUran” lectronica.
