Project disconnects from the Blynk server and does not connect anymore only after a reset
Friend, have you solved the problem of disconnecting?
My problem does not give any error in the serial but disconnects from the Blynk server and does not connect anymore only after a reset.
Can someone help me?
Can you post a sketch and confirm your connection method matches what is indicated by the sketch?
define BLYNK_PRINT Serial
#include "HX711.h"
char auth[] =“#########"";
char ssid[] = "*********";
char pass[] = "********";
#define DOUT  D3
#define CLK   D5
HX711 balanca(DOUT, CLK);
float calibration_factor = 23650;
delay(3000) ;
  Serial.println("Balança com HX711 - celula de carga 50 Kg");
  Serial.println("Pressione t para Tara");
  balanca.set_scale(calibration_factor);
  balanca.tare();
  Serial.print("Peso: ");
  Serial.print(balanca.get_units(), 3);
  Serial.println(" kg");
  Blynk.virtualWrite(V5, balanca.get_units(), 3);
  delay(3000) ;
  if (Serial.available())
    char temp = Serial.read();
    if (temp == 't' || temp == 'T')
      balanca.tare();
      Serial.println("Balançazerada");
Just Blynk and timer run in loop().
Just put that line of code in the Void Loop ?
No, the two x.run commands you already have and remove all the other stuff.
Friend you could be clearer, because I am using translator I am Brazilian and do not have much intimacy with programming.
I sending the skecth around here could you make the change and have it corrected?
Your code seems a bit odd anyway, regardless of the cluttered void loop.
Why are you watching the serial UART for incoming character before taking a weight reading? A much more sensible approach would be to add a Blynk switch widget and use that to trigger a weight reading, or add a Blynk timer to take a reading every x seconds.
As far as cleaning-up your void loop is concerned, you should read this:
Make it look like this
I’ll modify and see what’s going to happen
