Hey! Im pretty new to arduino and blynk and im working on a Projekt trying to connect the arduino DUE via bluetooth and a HC05 module, trying to send information from the Joystick in the blynk app to my PC serial monitor. I learned that the DUE doesn´t support SoftwareSerial (why are they used in the example for DUE projects?? lol) so im trying to get the code from the Blynk sketch creator to work on my DUE. I took out all the SoftwareSerial commands, since the Serial.print commands should use the standard RX/TX pins right? Yesterday i managed to at least get the compile to work with that and upload it to my DUE, but i can´t connect to the phone and app - just getting the “Waiting for connections…” message. My guess is that removing the BLE commands which stop the compile from working also removes the abillity for my components to communicate via bluetooth?
See the code below
char auth[] = "notsureifushouldseethiscodehaha";
BLYNK_WRITE(V1) {
int x = param[0].asInt();
int y = param[1].asInt();
// Do something with x and y
Serial.print("X = ");
Serial.print(x);
Serial.print("; Y = ");
Serial.println(y);
Blynk.begin(Serial, auth);
