Hey, I have problems with my project. I want to have ws2812 leds behind my bed, but my code doesn’t work.
my code:
#include "FastLED.h"
#define LED_PIN D1 // GPIO pin for RGB LEDs.
#define NUM_LEDS 60 // Number of LEDs connected.
#define LED_TYPE WS2812
#define COLOR_ORDER BRG
struct CRGB leds[NUM_LEDS]; //Initialisieren des LED-Arrays
int r = 0;
int g = 0;
int b = 0;
char auth[] = "21fdd48887ff4b498ada4d724d7c89ae";
uint8_t max_bright = 125;
Blynk.begin(auth, "Hope Siebzehn AP", "47275552990710462457");
LEDS.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS);
FastLED.setBrightness(max_bright);
FastLED.clear();
// This assumes there is a Blynk RGB widget writing data to virtual pin V1.
BLYNK_WRITE(V1)
r = param[0].asInt();
g = param[1].asInt();
b = param[2].asInt();
Serial.println("test");
BLYNK_WRITE(V2)
Serial.println("Knopf");
fill_solid(leds, NUM_LEDS, CRGB::Red);
FastLED.show();
FastLED.show();
I think it’s a problem with the Fastled library, but I think you can help me nonetheless. The LEDs work fine, because I tested them with another program that uses the adafruit library. But it’s old and bulky and I want to switch to the much faster fastleds.h library. Any help is much appreciated.
Where is that function, e.g. fill_solid(); ?
Do you get any errors or anything?
I edited your post too, added ``` before and after your code, it makes is pretty and readable
And you definitely want to remove fastled.show() from loop()!
Thanks, I will do it myself next time
I removed fastled.show() from my main loop, but about fill_solid()… Isn’t it some sort of built in function of fastled.h?
At least the documentation says so… I may be confusing something?
I mean, I don’t get any errors, It just doesn’t work when I try to use zergba or a simple button.
FastLED.fill_solid doesn’t work, though.
No, it’s just a function calling, so it has to be defined in your sketch.
Does it work when you use a FastLED example, thus without Blynk?
I will try that.
I mean, the Blynk thyng works and all, but fastled gives me headaches.
Just wait a minute or two, will you?
Edit:
Strange, when I upload my (stolen) test code, nothing happens.
Sady I can’t show it here, something about “new user” and “you can’t have more than to links” or something.
Put this in void setup(); to test if the leds actually work:
int i;
for(i=0;i<NUM_LEDS;i++)
LEDS[i] = CRGB::White;
FastLED.show();
They should light up white if it’s wired ok and so on.
Hey, thanks for the example code, but it gives me this error:
Arduino: 1.8.5 (Linux), Board: “NodeMCU 1.0 (ESP-12E Module), 80 MHz, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Sketch + WiFi Settings, 57600”
In file included from /root/Schreibtisch/Testlauf/Testlauf.ino:4:0:
/root/Arduino/libraries/FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.007
pragma message “FastLED version 3.001.007”
In file included from /root/Arduino/libraries/FastLED/FastLED.h:68:0,
/root/Arduino/libraries/FastLED/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
pragma message “No hardware SPI pins defined. All SPI access will default to bitbanged output”
/root/Schreibtisch/Testlauf/Testlauf.ino: In function ‘void setup()’:
Testlauf:37: error: no match for ‘operator=’ (operand types are ‘CLEDController’ and ‘CRGB::HTMLColorCode’)
/root/Schreibtisch/Testlauf/Testlauf.ino:37:13: note: candidates are:
In file included from /root/Arduino/libraries/FastLED/FastLED.h:50:0,
/root/Arduino/libraries/FastLED/controller.h:39:7: note: CLEDController& CLEDController::operator=(const CLEDController&)
class CLEDController {
/root/Arduino/libraries/FastLED/controller.h:39:7: note: no known conversion for argument 1 from ‘CRGB::HTMLColorCode’ to ‘const CLEDController&’
/root/Arduino/libraries/FastLED/controller.h:39:7: note: CLEDController& CLEDController::operator=(CLEDController&&)
/root/Arduino/libraries/FastLED/controller.h:39:7: note: no known conversion for argument 1 from ‘CRGB::HTMLColorCode’ to ‘CLEDController&&’
exit status 1
I don’t know if it helps you, it does not help me
Oops, ignore that SPI error, commong thing with fastled but has nothing to do with my problem.
Sooo, I tried it again with this:
leds[i] = CRGB( 50, 100, 150);
It gives me no errors, but it doesn’t work again. Strangely enough, the LEDs work flawlessly with the adafruit library.
What am I doing wrong?
Hello? Anyone there? Might just keep using adafruit’s library.
There are plenty of discussions and examples. Please use google. Closing this.
