Hi
I cannot get any app to upload to my EP12 WiFi module???
Arduino IDE compiles well but the fail upload with following error, please Help?
Arduino: 1.8.0 (Windows 10), Board: “Generic ESP8266 Module, 80 MHz, ck, 26 MHz, 40MHz, QIO, 512K (no SPIFFS), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200”
Sketch uses 264076 bytes (52%) of program storage space. Maximum is 499696 bytes.
Global variables use 34560 bytes (42%) of dynamic memory, leaving 47360 bytes for local variables. Maximum is 81920 bytes.
C:\Users\Theo\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.13/esptool.exe -vv -cd ck -cb 115200 -cp COM5 -ca 0x00000 -cf C:\Users\Theo\AppData\Local\Temp\arduino_build_805547/Joystick_test.ino.bin
esptool v0.4.13 - © 2014 Ch. Klippel ck@atelier-klippel.de
setting board to ck
setting baudrate from 115200 to 115200
setting port from COM1 to COM5
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
An error occurred while uploading the sketch
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
“Show verbose output during compilation”
