Hello to all
I use Arduino Leonardo and Sim 800 in my connection project With communication gsm
I have no problem activating or deactivating GPIOs
In the automation section of all timers and notifications, everything works fine, but there is a problem.
««« When I want to say if variable v0 Enabled or disabled(is on & is off)
But on or off is not detected but commands has changed & is any They work properly »» »»
What do you think could be the problem?
Note: I use the same automation esp32 And I tested Wi-Fi and it had no problem, but it has problems with Arduino, 800 SIM and GSM mode.
