Hi, everyone!! I’m having some troubles to send humidity and temperature data, using a DHT11, to Blynk using an Arduino Uno and Ethernet Shield ENC28J60. I noticed, after some tests, that Arduino get lost his connection with Blynk server, when the BlynkTimer or SimpleTimer server are used in code, not sending any data correctly and losing the connection.
The code used:
/* Fill-in your Template ID (only if using Blynk.Cloud) */
#define BLYNK_TEMPLATE_ID "templateID"
#include <DHT.h>
#include <UIPEthernet.h>
#include <BlynkSimpleUIPEthernet.h>
// You should get Auth Token in the Blynk App
char auth[] = "myauth";
#define DHTPIN 6
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
//SimpleTimer timer;
//Função do Sensor DHT11
void sensorDHT() {
float h = dht.readHumidity();
Blynk.virtualWrite(V6, t);
Blynk.virtualWrite(V7, h);
void setup(){
dht.begin();
Blynk.begin(auth);
timer.setInterval(1000L, sensorDHT);
sensorDHT();
First edit your post and add triple backticks at the beginning and the end of your sketch. Triple backticks look like this ```
Second try this sketch :
For this example you need UIPEthernet library:
https://github.com/UIPEthernet/UIPEthernet
Typical wiring would be (this is for Arduino UNO,
search for correct wiring for your board):
VCC -- 5V
GND -- GND
CS -- D10
SI -- D11
SCK -- D13
SO -- D12
INT -- D2
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
#include <DHT.h>
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
void sendSensor()
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.begin(auth);
//Blynk.begin(auth, "blynk.cloud", 80);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
dht.begin();
I’ve tried this Sketch you sent here, but still isn’t sending the DHT11 data to Blynk, not even keeping connection with the Arduino board and the Blynk server.
The connection is OK, about the used pins, alright… Different library versions didn’t work as well. The Arduino keeps doesn’t connecting to the Blynk and no sending any data.
@svalbard Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
