I have problems with adding a new device. I have try everything twice and with a new esp8266 module.
My problem is that I can’t add the new device and always the procedure sticks on the last step.
Below the output from the serial monitor.
>[389]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.0.1 on ESP8266
[393] --------------------------
[396] Product: Water Tank Roof 2
[399] Firmware: 2.0.0 (build Aug 12 2021 09:46:12)
[403] Device: ESP8266 @ 80MHz
[406] MAC: 24:A1:60:30:0A:5A
[409] Flash: 4096K
[411] ESP core: 3.0.2
[413] ESP SDK: 2.2.2-dev(38a443e)
[416] Boot Ver: 6
[418] Boot Mode:1
[420] FW info: 472160/1622016, MD5:13c6cb3397e193da9d7301efbc4da9b4
[629] Free mem: 30096
[629] --------------------------
[629] INIT => WAIT_CONFIG
[1239] AP SSID: Blynk Water Tank Roof 2-636E5
[1240] AP IP: 192.168.4.1
[1240] AP URL: blynk.setup
After this I follow the steps to add a new device from the mobile phone and the output from the serial monitor:
[128488] WAIT_CONFIG => CONFIGURING
[132504] CONFIGURING => WAIT_CONFIG
[163166] WAIT_CONFIG => CONFIGURING
[165880] Sending board info...
[166007] Scanning networks...
[168194] Found networks: 8
[240571] Applying configuration...
[240572] WiFi SSID: xxxxxxxxxxxxxxxxx Pass: xxxxxxxxxxxxx
[240572] Blynk cloud: glDEzlez9FjNVpn2EXnFkR_qOqzN6W4o @ blynk.cloud:443
[240577] CONFIGURING => SWITCH_TO_STA
100
mm
and it stops again on the “Waiting for the device”.
I have some where found on the net I have to change the “AP IP: 192.168.4.1” is that correct?
Thanks!
