Problem wtih Blynk Local server
hi
i have seacrh bu don’t find information for my problem.
I have test blynk with cloud server , the test is ok my wemos D1 is working.
I have install local server on raspberry pi
the server is ok , it s possible for me to connect my android application to rasp server.
i see this message on blynk.log : "fabr....@hotmail.com blyn-app (android…) joined
but on my android application, my wemos is “wasnt online yet”
With your Android app logged-in to the local server, have you created a project and used the auth code for that project in your Wemos D1 sketch?
Also, have you changes your Wemos sketch so that it connects to your local server rather than the Blynk cloud server?
I’m guessing that you’re using a cloud server auth code on your Wemos at the moment, and still trying to connect to the cloud server.
What does the serial output from your Wemos show - it should give you some clues.
thank’s
my code for the wemos use a new auth code and i have change cloud server by my ip server
see :
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  You’ll need:
   - Blynk App (download from AppStore or Google Play)
   - WeMos D1 board
  started. Think of them as LEGO bricks  and combine them as you wish.
  example.
char auth[] = "aa036AAAAAAAA1fffb768e";
char ssid[] = "broAAAAAssier";
char pass[] = "AAAAAAAAAAA";
  pinMode(D1,OUTPUT);
  pinMode(D2,OUTPUT);
  pinMode(D5,OUTPUT);
  pinMode(D6,OUTPUT);
  pinMode(D7,OUTPUT);
  pinMode(D8,OUTPUT); // ajouter les sortie D utilisé
  digitalWrite(D1,LOW); // niveau automotique en cas de coupure low=0 high=1
  digitalWrite(D2,LOW);
  digitalWrite(D5,LOW);
  digitalWrite(D6,LOW);
  digitalWrite(D7,LOW);
  digitalWrite(D8,LOW);
  //Blynk.begin(auth, ssid, pass);
  **Blynk.begin(auth, ssid, pass, IPAddress(192,168,0,11), 80);**
  // to avoid delay() function!
i see a default on the log fil off blynk server :
WARN - ATTENTION. Server certificate paths (cert : ‘/etc/letsencrypt/live/192.168.0.11/fullchain.pem’, key : ‘/etc/letsencrypt/live/192.168.0.11/privkey.pem’) not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs
I’ve edited your code so that it displays correctly. In future you should do this:
Blynk%20-%20FTFC
ok thank’s, do you have an idea for my problem please
I’m not a local server user, but I do know that the output from your serial monitor would help those that are to understand more about what is happening when your device tries to connect.
Posting that between backtics makes it display correctly as well :grinning:
Default hardware port for Local Server is 8080, not juist 80.
ok thank’s
but
I corrected my mistake
reprogram with 8080
but still the same problem
can you give us the serial log?
Third time lucky???
yes
08:52:48.652 INFO - Using data dir '/home/pi/Blynk'
08:52:50.813 INFO - Region : local. Host : 127.0.1.1.
08:52:52.363 INFO - Initializing gmail smtp mail transport. Username : fabricebrossier@hotmail.com. SMTP host : smtp.live.com:25
08:52:52.458 INFO - Reports : 0
08:52:52.463 INFO - Didn't find Let's Encrypt certificates.
08:52:52.463 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
08:52:52.473 WARN - ATTENTION. Server certificate paths (cert : '/etc/letsencrypt/live/192.168.0.11/fullchain.pem', key : '/etc/letsencrypt/live/192.168.0.11/privkey.pem') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
08:52:53.681 INFO - HTTP API and WebSockets server listening at 8080 port.
08:52:53.687 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
08:52:53.689 INFO - Mqtt hardware server listening at 8440 port.
08:53:24.957 INFO - fabricebrossier@hotmail.com Blynk-app (android-22702) joined.
That looks like a server log rather than the serial output from your Wemos D1.
I swung and missed.
To get your serial log, using the arduino ide, you’ll want to go here.
and then, this is the log we all should be looking at to help troubleshoot.
ok
i do this :
this log confirm my wemos D1 is connect to my server 192.168.0.11
but in the blynk app is not online
It confirms that it’s trying to connect, but hasn’t yet been successful.
The first screenful of data that’s printed to the serial monitor when the device first boots should contain more info. That’s what I was hoping you’d share.
J’ai redémarer mon tel android et tout fonctionne.
merci pour votre aide
