The weirdest thing, i have written a sketch for dimming up and dimming down leds using FadeLed library. Everything works well as when i am not using wifi manager. As soon as i insert the wifi manager stuff it disconnects and does not reconnect. Am i missing something? The wifi code used is the same as i have used for other projects and they work well…
CODE WHICH WORKS WITHOUT WIFI MANAGER
//#define BLYNK_PRINT Serial
#include <WidgetRTC.h>
#include <FadeLed.h>
WidgetRTC rtc;
//WIFI Variables
char auth[] = "";
char ssid[] = "";
char pass[] = "";
//RTC/Time Input Widget Variables
char currentTime[9];
char currentDate[11];
char startTime[9];
char stopTime[9];
int SThour;
int STmin;
int STsec;
int SPhour;
int SPmin;
int SPsec;
int dayNumber;
bool activeToday = false;
bool scheduler = true;
bool schedulerStatusChange = false;
//LED FADE ATTRIBUTES & VARIABLES
FadeLed CH1(D4);
int FadeIN = 0;
int FadeOUT = 0;
int maxPWM;
unsigned long FadeInTime;
unsigned long FadeOutTime;
void LedFadeIn ()
CH1.setTime(FadeInTime);
CH1.set(maxPWM);
void LedFadeOut ()
CH1.setTime(FadeOutTime);
CH1.set(0);
BLYNK_WRITE(V1) //CH1 TIME IMPUT WIDGET
TimeInputParam t(param);
SThour = t.getStartHour();
STmin = t.getStartMinute();
STsec = t.getStartSecond();
SPhour = t.getStopHour();
SPmin = t.getStopMinute();
SPsec = t.getStopSecond();
dayNumber = weekday();
unsigned int OnDays = 0;
for (int i = 1; i <= 7; i++) // Process weekdays (1-Mon, 2-Tues, 3-Wed, 4-Thurs, 5-Fri, 6-Sat, 7-Sun)
if (t.isWeekdaySelected(i))
OnDays++;
if(i==dayNumber)
activeToday = true;
Serial.println(String("Day ") + i + " is selected");
if (OnDays == 0)
scheduler = false;
scheduler = true;
if (scheduler != schedulerStatusChange)
schedulerStatusChange = scheduler;
BLYNK_WRITE(V2) //CH1 FADEIN TIME WIDGET
FadeIN = param.asInt();
FadeInTime = (FadeIN * 60000); //Param is in minutes
Serial.print("LedFadeIn Time: ");
Serial.println(FadeInTime);
BLYNK_WRITE(V3) //CH1 FADEOUT TIME WIDGET
FadeOUT = param.asInt();
FadeOutTime = (FadeOUT * 60000);
Serial.print("LedFadeOut Time: ");
Serial.println(FadeOutTime);
BLYNK_WRITE(V4) //CH1 UV INTENSITY WIDGET
maxPWM = param.asInt();
Serial.print("Intensity: ");
Serial.println(maxPWM);
void ProgressBar()
//int CL;
CH1.getCurrent();
//CL = (maxPWM / CH1.getCurrent()*100.0);
Serial.print("Progress: ");
Serial.println(CH1.getCurrent());
Blynk.virtualWrite(V5, CH1.getCurrent());
void TimeCheck()
sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second()); //Get RTC time
Serial.print("Current Time: ");
Serial.println(currentTime);
sprintf(startTime, "%02d:%02d:%02d", SThour, STmin, STsec); //Get start time from widget
Serial.print("Start Time: ");
Serial.println(startTime);
sprintf(stopTime, "%02d:%02d:%02d", SPhour, SPmin, SPsec); //Get stop time from widget
Serial.print("Stop Time: ");
Serial.println(stopTime);
if (activeToday == true)
if (hour() == SThour)
if (minute() == STmin)
LedFadeIn();
Serial.println("Doing something now");
else if (hour() == SPhour)
if (minute() == SPmin)
LedFadeOut();
Serial.println("Stopping something now");
void ClockDisplay()
sprintf(currentDate, "%02d/%02d/%04d", day(), month(), year());
Blynk.virtualWrite(V6, currentTime); //Send time to TIME widget
Blynk.virtualWrite(V7, currentDate); //Send date to DATE widget
BLYNK_CONNECTED() //Connect to Blynk server
Blynk.syncAll();
void SyncChannels()
//CH1.update();
FadeLed::update();
//Blynk.begin(auth, ssid, pass);
//CH1 = LEDFader(Channel1);
//CH1.set_value(0);
CH1.set(0);
rtc.begin();
setSyncInterval(30);
timer.setInterval(1000L, ClockDisplay);
timer.setInterval(500L, TimeCheck);
timer.setInterval(10L, SyncChannels);
timer.setInterval(500L, ProgressBar);
//CH1.update();
CODE WHICH DOES NOT WORK WITH WIFI MANAGER
//LIBRARIES//
#include <FS.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <BlynkSimpleEsp8266.h> //MUST BE IN THIS ORDER
//#include <ArduinoOTA.h>
//#include <ESP8266mDNS.h> //For OTA w/ ESP8266
// #include <ESPmDNS.h> //For OTA w/ ESP32
//#include <WiFiUdp.h>
WidgetRTC rtc;
//PIN ASSIGNMENTS//
//RTC & TIME IMPUT ATTRIBUTES & VARIABLES
char currentTime[9]; //RTC time
char currentDate[11]; //RTC date
char startTime[9];
char stopTime[9];
int SThour;
int STmin;
int STsec;
int SPhour;
int SPmin;
int SPsec;
int dayNumber;
//WIFI GLOBALS//
char mqtt_server[40];
char mqtt_port[6] = "8080";
char blynk_token[34] = "YOUR_BLYNK_TOKEN";
bool shouldSaveConfig = false;
//char modulename[] = "AquArt Blynk Test"; //Insert app name
FadeLed CH1(D1);
int FadeIN = 0;
int FadeOUT = 0;
int maxPWM;
float PWMint;
//CONNECT TO BLYNK SERVER//
BLYNK_CONNECTED()
Blynk.syncAll();
rtc.begin();
void saveConfigCallback ()
shouldSaveConfig = true;
if (SPIFFS.begin())
if (SPIFFS.exists("/config.json"))
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile)
size_t size = configFile.size();
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success())
strcpy(mqtt_server, json["mqtt_server"]);
strcpy(mqtt_port, json["mqtt_port"]);
strcpy(blynk_token, json["blynk_token"]);
WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 6);
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 33);
WiFiManager wifiManager;
wifiManager.setSaveConfigCallback(saveConfigCallback);
wifiManager.addParameter(&custom_mqtt_server);
wifiManager.addParameter(&custom_mqtt_port);
wifiManager.addParameter(&custom_blynk_token);
wifiManager.resetSettings(); //Used for reset only comment out if not needed
if (!wifiManager.autoConnect("AquArt Blynk Test", "password")) //Insert App name
delay(3000);
//ESP.reset();
//delay(5000);
strcpy(mqtt_server, custom_mqtt_server.getValue());
strcpy(mqtt_port, custom_mqtt_port.getValue());
strcpy(blynk_token, custom_blynk_token.getValue());
if (shouldSaveConfig)
JsonObject& json = jsonBuffer.createObject();
json["mqtt_server"] = mqtt_server;
json["mqtt_port"] = mqtt_port;
json["blynk_token"] = blynk_token;
File configFile = SPIFFS.open("/config.json", "w");
json.printTo(configFile);
configFile.close();
Blynk.config(blynk_token);
bool result = Blynk.connect();
if (result != true)
ESP.reset();
delay (5000);
//ArduinoOTA.setHostname(modulename);
//ArduinoOTA.begin();
//OTHER SET UP STUFF HERE
CH1.set(0);
rtc.begin();
//ArduinoOTA.handle();
void ClockDisplay()
OnDays++;
if(i==dayNumber)
activeToday = true;
if (OnDays == 0)
scheduler = false;
scheduler = true;
PWMint = param.asInt();
maxPWM = map(PWMint, 0, 100, 0, 255);
void TimeCheck()
LedFadeIn();
LedFadeOut();
void LedFadeIn ()
CH1.setTime(FadeInTime, true);
CH1.set(maxPWM);
void LedFadeOut ()
CH1.setTime(FadeOutTime, true);
CH1.set(0);
void ProgressBar()
CH1.getCurrent();
void SyncChannels()
FadeLed::update();
//END//
