Dear All!
I have faced with a very strange problem with my automatization project.
It is a very basic program to control 4 relays with Arduino MEGA and SIM800L GSM module. I have EVB ROHS GSM breakboard, so I can power it with 5V 2A (I have tested with AT commands, it works great). I use it with iOS (v15.6) all my Blynk (v1.1.0) and TinyGSM (v0.11.5) library are UpToDate. I use Blynk Server.
Sometimes the program continuously run for more hours (up to half day, without any problem), sometimes run it for hours but there are lot of connection failure, but it can reboot, and sometimes after several reboot, it is not able to reconnect, anymore I have message: Connection to blynk-coud.com:80 (neither 8080).
I have read all the related topics, but I couldn’t find the solution.
Is anybody who faced with this kind of problem, or is there anybody, who knows what can be the problem?
I have 2 questions left:
- is is possible to run his code(after migration) without problem on Blynk2.0 ? or I would struggle with the same problem
- this message (Connection to blynk-coud.com:80) means: my GPRS connection OK (as it said duing init), but I can’t reach the server or I understand it wrong?
Here is my code:
#define BLYNK_DEBUG
#define BLYNK_AUTH_TOKEN "F50xR-ZqwHU3bxGQM_i0YqpiPoFQr9Eb"
#define TINY_GSM_MODEM_SIM800
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
//#include <BlynkSimpleSIM800.h>
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "internet.telekom";
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial3
// or Software Serial on Uno, Nano
//#include <SoftwareSerial.h>
//SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
// in Blynk app writes values to the Virtual Pin V1
int RelayControl1 = 24; // I/O az 1. körhöz
int RelayControl2 = 25; // I/O az 2. körhöz
int RelayControl3 = 26; // I/O az 3. körhöz
int RelayControl4 = 27; // I/O az 4. körhöz
BLYNK_CONNECTED() {
Blynk.syncAll();
pinMode(RelayControl1, OUTPUT);
pinMode(RelayControl2, OUTPUT);
pinMode(RelayControl3, OUTPUT);
pinMode(RelayControl4, OUTPUT);
digitalWrite(RelayControl1,HIGH);
digitalWrite(RelayControl2,HIGH);
digitalWrite(RelayControl3,HIGH);
digitalWrite(RelayControl4,HIGH);
// Set GSM module baud rate
SerialAT.begin(9600);
delay(800);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
//Blynk.begin(auth, modem, apn, user, pass, "blynk-cloud.com", 8080);
timer.setInterval(1000L, ellen);
void ellen(){
if (Blynk.connected()==0) {
Serial.println("Reload");
Blynk.disconnect();
Thanks in advance,
Tamas
