I’m currently working on PZEM-017 to measure the voltage and energy usage of my solar system.
I had PZEM-017 connect to “TTL to RS485 Module ” and ESP8266
Here I can not display the voltage results that I read. But when using the pzem-03 master the voltage is read. help me to get the value i want.
this is my program.
#define BLYNK_TEMPLATE_ID "xxxxxxx"
#define BLYNK_DEVICE_NAME "xxxxxxx"
#define BLYNK_AUTH_TOKEN "xxxxxxx"
#define BLYNK_FIRMWARE_VERSION "1.1.0"
SoftwareSerial PZEMSerial;
char auth[] = "xxxxxxx";
char ssid[] = "xxxxxx";
char pass[] = "xxxxxxx";
#include <ModbusMaster.h>
#define MAX485_DE 16
#define MAX485_RE 5
static uint8_t pzemSlaveAddr = 0x01;
static uint16_t NewshuntAddr = 0x0001;
ModbusMaster node;
float PZEMVoltage =0;
float PZEMCurrent =0;
float PZEMPower =0;
float PZEMEnergy=0;
unsigned long startMillisPZEM;
unsigned long currentMillisPZEM;
const unsigned long periodPZEM = 1000;
unsigned long startMillisReadData;
unsigned long currentMillisReadData;
const unsigned long periodReadData = 1000;
int ResetEnergy = 0;
int a = 1;
unsigned long startMillis1;
startMillis1 = millis();
PZEMSerial.begin(9600,SWSERIAL_8N2,4,0);
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
startMillisPZEM = millis();
pinMode(MAX485_RE, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
digitalWrite(MAX485_RE, 0);
digitalWrite(MAX485_DE, 0);
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
node.begin(pzemSlaveAddr,PZEMSerial);
startMillisReadData = millis();
if ((millis()- startMillis1 >= 10000) && (a ==1))
setShunt(pzemSlaveAddr);
changeAddress(0XF8, pzemSlaveAddr);
a = 0;
currentMillisPZEM = millis();
if (currentMillisPZEM - startMillisPZEM >= periodPZEM)
uint8_t result;
result = node.readInputRegisters(0x0000, 6);
if (result == node.ku8MBSuccess)
uint32_t tempdouble = 0x00000000;
PZEMVoltage = node.getResponseBuffer(0x0000) / 100.0;
PZEMCurrent = node.getResponseBuffer(0x0001) / 100.0;
tempdouble = (node.getResponseBuffer(0x0003) << 16) + node.getResponseBuffer(0x0002);
PZEMPower = tempdouble / 10.0;
tempdouble = (node.getResponseBuffer(0x0005) << 16) + node.getResponseBuffer(0x0004);
PZEMEnergy = tempdouble;
if (pzemSlaveAddr==2)
startMillisPZEM = currentMillisPZEM ;
currentMillisReadData = millis();
if (currentMillisReadData - startMillisReadData >= periodReadData)
Serial.print("Vdc : "); Serial.print(PZEMVoltage); Serial.println(" V ");
Serial.print("Idc : "); Serial.print(PZEMCurrent); Serial.println(" A ");
Serial.print("Power : "); Serial.print(PZEMPower); Serial.println(" W ");
Serial.print("Energy : "); Serial.print(PZEMEnergy); Serial.println(" kWh ");
Blynk.virtualWrite(V0,PZEMVoltage);
Blynk.virtualWrite(V1,PZEMCurrent);
Blynk.virtualWrite(V2,PZEMPower);
Blynk.virtualWrite(V3,PZEMEnergy);
void preTransmission()
if(millis() - startMillis1 > 5000)
digitalWrite(MAX485_RE, 1);
digitalWrite(MAX485_DE, 1);
delay(1);
void postTransmission()
delay(3);
void setShunt(uint8_t slaveAddr)
static uint8_t SlaveParameter = 0x06;
static uint16_t registerAddress = 0x0003;
uint16_t u16CRC = 0xFFFF;
u16CRC = crc16_update(u16CRC, slaveAddr);
u16CRC = crc16_update(u16CRC, SlaveParameter);
u16CRC = crc16_update(u16CRC, highByte(registerAddress));
u16CRC = crc16_update(u16CRC, lowByte(registerAddress));
u16CRC = crc16_update(u16CRC, highByte(NewshuntAddr));
u16CRC = crc16_update(u16CRC, lowByte(NewshuntAddr));
preTransmission();
PZEMSerial.write(slaveAddr);
PZEMSerial.write(SlaveParameter);
PZEMSerial.write(highByte(registerAddress));
PZEMSerial.write(lowByte(registerAddress));
PZEMSerial.write(highByte(NewshuntAddr));
PZEMSerial.write(lowByte(NewshuntAddr));
PZEMSerial.write(lowByte(u16CRC));
PZEMSerial.write(highByte(u16CRC));
postTransmission();
delay(100);
BLYNK_WRITE(V4)
if(param.asInt()==1)
static uint8_t resetCommand = 0x42;
uint8_t slaveAddr = pzemSlaveAddr;
u16CRC = crc16_update(u16CRC, resetCommand);
preTransmission();
PZEMSerial.write(resetCommand);
postTransmission();
delay(100);
void changeAddress(uint8_t OldslaveAddr, uint8_t NewslaveAddr)
static uint16_t registerAddress = 0x0002;
u16CRC = crc16_update(u16CRC, OldslaveAddr);
u16CRC = crc16_update(u16CRC, highByte(NewslaveAddr));
u16CRC = crc16_update(u16CRC, lowByte(NewslaveAddr));
preTransmission();
PZEMSerial.write(OldslaveAddr);
PZEMSerial.write(highByte(NewslaveAddr));
PZEMSerial.write(lowByte(NewslaveAddr));
postTransmission();
delay(100);
