Problem with multiple virtualWrite() calls in sequence
Hi everyone.
I have a weird issue I could really use help with.
I have a simple sketch below:
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "";
// Conversion factor for micro seconds to seconds
#define uS_TO_S_FACTOR 1000000
// Time ESP32 will go to sleep (in seconds)
#define TIME_TO_SLEEP 15
// holds the total boot counts
RTC_DATA_ATTR int bootCount = 0;
char ssid[] = "";
char pass[] = "-()-";
// Moisture sensor is connected to GPIO 34 (Analog ADC1_CH6)
const int sensorPin = 34;
// variable for storing the moisture sensor value
int sensorValue = 0;
// this function reads the sensor values and send them to blynk
void publishSensorValues()
  // Reading moisture sensor value
  sensorValue = analogRead(sensorPin);
  // Sending to blynk
  Blynk.virtualWrite(V0, sensorValue);
    // Wait until connected
  // Send uptime
  Blynk.virtualWrite(V1, bootCount);
  delay(500); //Take some time to open up the Serial Monitor
  //Increment boot number and print it every reboot
  ++bootCount;
  Serial.println("Boot number: " + String(bootCount));
  // schedule a wakeup in the future
  esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
  // connect to blynk
  // read and publish the sensor values
  publishSensorValues();
  Serial.println("Going to sleep now");
  Serial.flush();
  esp_deep_sleep_start();
I realized if I take out this piece:
then only the first Blynk.virtualWrite(V0, sensorValue) succeeds. If I swap V1 and V0, then V1 succeeds.
Which one is the first, that one succeeds.
But if I put while (Blynk.connect() == false) back, then both succeed.
BUT–I get a double connection statements in the console:
21:44:13.197 → [1615] Connecting to blynk-cloud.com:80
21:44:13.296 → [1722] Ready (ping: 48ms).
21:44:18.296 → [6723] Connecting to blynk-cloud.com:80
21:44:18.429 → [6860] Ready (ping: 43ms).
so, either one virtualWrite succeeds or I have double connections.
Can someone please help?
Thank you!!
I’m pretty sure Blynk.connect() is a blocking function anyway so you could try to remove this:
And just put this at the start of your function:
Blynk.connect();
Coding for deep sleep is very different to regular Blynk coding - where the void loop needs to be kept clean. With deep sleep, the opposite is true, you want the void loop to execute once, so you put everything in there.
I have no experience of coding ESP32s for deep sleep, but i think the general principals should be the same.
Your code contains no Blynk.run(); commands, which in my experience are needed to get most Blynk functions to work correctly. You’re also trying to use Blynk.connect when I suspect that you should be using Blynk.connected()```
Also, using Blynk.begin, which is a blocking function, isn’t good for battery powered devices as a failure to connect to Wi-Fi or Blynk will result in the device continually trying to connect until it either succeeds or the batteries are flat.
It’s better to use do your own Wi-Fi connection management then use Blynk.config and Blynk.connect.
Here’s a bit of code that I contributed to in the earlier stages when it was running on an ESP8266, but was then ported over to ESP32 by @christophebl and he reports that it’s working well for him…
Unfortunately, that didn’t work :frowning:
the new function:
  Blynk.connect();
  // Sending to blynk
  // Send uptime
Still double connections:
08:35:03.769 → [1582] Connecting to blynk-cloud.com:80
08:35:04.365 → [2185] Ready (ping: 41ms).
08:35:09.365 → [7186] Connecting to blynk-cloud.com:80
08:35:09.630 → [7430] Ready (ping: 190ms).
I think the ā€œdouble connectionsā€ are because your device isn’t talking to the Blynk server after the first connection, so it then tries to re-connect.
This is because of the lack of Blynk.run statements.
Any ā€˜while/wend’ command is also likely to cause disconnections unless there’s a Blynk.run command in the loop.
ā€œDouble Connectionsā€ happen because Blynk.connect() is called again. Use Blynk.connected() to check if there is connection.
Try this code
#include <WiFi.h>
char auth[] = "****************";
char cloudBlynkServer[] = "****";
char ssid[] = "****";
char pass[] = "****";
  #define KAVG      10
  sensorValue = 0;
  for (int i = 0; i < KAVG; i++)  //
    sensorValue += analogRead(sensorPin);
    delay(20);
  sensorValue = sensorValue / KAVG;
  // Sending to blynk
  Blynk.virtualWrite(V5 /*V0*/, sensorValue);
  // Send uptime
  Blynk.virtualWrite(V3 /*V1*/, bootCount);
#define BLYNK_SERVER_HARDWARE_PORT    8080
  ++bootCount;
  // connect to blynk
  Blynk.begin(auth, ssid, pass, cloudBlynkServer, BLYNK_SERVER_HARDWARE_PORT);
  if (Blynk.connected())
  Serial.flush();
  Blynk.disconnect();
Thank you, will try tonight.
ok, this is a neat trick–you are taking 20 readings and then averaging them?
Hehe… cute :slight_smile:
Is this a typical pattern for reading sensor values?
(very cool, btw).
Will try this tonight also–thank you, thank you!
to be fair, I removed Blynk.run based on this and other searchable discussions.
This could be my ignorance though. I’m still not sure it’s needed but happy to add if required.
Thank you.
I think that dispensing with Blynk.run is a risky strategy, and the effects aren’t really well understood.
I’ve seen other discussions where a timer can call a function that contains Blynk.run, but I’m not really convinced and it doesn’t have a place in the code that you’re using.
As far as what you’re trying to achieve, I’d read through the comments that are in beehive code that I linked to. It’s well commented (I know because I put them in there :blush:) and I’m told that it the code works well.
Just tried this, it works–thank you!!
Understood.
Going over the bee code now, there’s quite a bit to unpack there.
Thank you for your help.
For future reference, this is the code that works:
thank you @khoih and @PeteKnight for all your help!
#include <WiFi.h>
char auth[] = "";
char ssid[] = "";
  // how many readings to take
  #define MAX_SENSOR_READS 10
  // Reading moisture sensor values
  for (int i = 0; i < MAX_SENSOR_READS; i++)
    delay(20);
  sensorValue = sensorValue / MAX_SENSOR_READS;
  // Sending to blynk
  // Send uptime
  ++bootCount;
 // setup the connection to blynk
  Blynk.config(auth);
  // setup WiFi
  Blynk.connectWiFi(ssid, pass);
  //will continue trying to connect to Blynk server.
  //Returns true when connected, false if timeout has been reached.
  //Default timeout is 30 seconds.
  bool result = Blynk.connect();
  Serial.flush();
  Blynk.disconnect();
I’m not sure why you’re saving the outcome of the Blynk.connect() test to the variable ā€˜result’ if you’re not going to use it in the next stage. Wouldn’t it be better to do this:?
  if (result)
Absolutely. Fixed!
:wink:
