My English is not so good, because Iam from India and Iam studying in 10th.
I have a problem with my project home automation with using esp8266 and blynk app. it connected to WIFI but it is showing "Home automation wasn’t online yet "
Here’s the code
char auth[] = "VfhFBBSm19xN03B3BW5k1WGwbVUxN-fH"; // the auth code that you got on your gmail
char ssid[] = "Muqthadir"; // username or ssid of your WI-FI
char pass[] = "muqthadir"; // password of your Wi-Fi
pinMode(D1,OUTPUT); //extend these to D8 if you are using a 8 pin relay
pinMode(D2,OUTPUT);
pinMode(D3,OUTPUT);
pinMode(D4,OUTPUT);
digitalWrite(D1,HIGH); // Make it low if you want everything to go off
digitalWrite(D2,HIGH); // in case of a power cut
digitalWrite(D3,HIGH);
digitalWrite(D4,HIGH);
