For some reason, my code works just fine in that tests are measured and executed, the serial monitor displays the correct strings, and my Blynk app receives and displays readings from 1-RTC and 2-temp sensors, as intended, but for some reason, only the digitalWrite(); commands are not executed. The serial.print(); lines that are bunched up with the respective digitalWrite(); are executed, but not the digital writes.
I don’t know if there is a conflict between Blynk and INPUT_PULLUP, but I doubt it as I see quite a few other Blynk sketches being shared using the input_pullup. Can someone review my code and help me figure out why these digitalWrite(); commands are not executed?
#include <SPI.h> // Used by Blynk
#include <Ethernet.h> // Used by Blynk
#include <BlynkSimpleEthernet.h> // Used by Blynk
#include <Wire.h> // I2c
#include "DHT.h" // DHT data wire connected to I/O pin with a 10k pullup resistor to 5V
#include <SimpleTimer.h> // used to run functions at preset intervals
#include "RTClib.h" // RealTimeClock Library for DS1307 and DS3231
// DHT Reference Values - CHANGE THESE TO MANAGE YOUR ROOM'S CLIMATE - //
byte hiMaxTemp = 90; // temp that triggers heat removal fan on
byte lowMaxTemp = 75; // temp that triggers heat removal fan off
byte hiMinTemp = 70; // temp that triggers heater on
byte lowMinTemp = 60; // temp that triggers heater off
byte hiHum = 75; // High humidity value that triggers dehumidifier on
byte lowHum = 70; // Low humidity value that triggers dehumidifier off
//Digital Pin Peristaltic Pump Dosing Heads - 00 Series Pins - PWM/12v motors
#define GHfloraGro 2 //Pump 1 - Primary Nutrient - nutePumps[0]
#define GHfloraMicro 3 //Pump 2 - Primary Nutrient - nutePumps[1]
#define GHfloraBloom 4 //Pump 3 - Primary Nutrient - nutePumps[2]
#define GHfloraBlend 5 //Pump 4 - Metabolic Supplement - nutePumps[3]
#define GHarmorSi 6 //Pump 5 - Silica Supplement (raises pH) - nutePumps[4]
#define GHcaliMagic 7 //Pump 6 - Calcium/Magnesium Supplement - nutePumps[5]
#define GHkoolBloom 8 //Pump 7 - Bloom Supplement - nutePumps[6]
#define GHphDown 9 //Pump 8 - pH Lowering Agent - nutePumps[7]
int nutePumps[8] {GHfloraGro, GHfloraMicro, GHfloraBloom, GHfloraBlend, GHarmorSi, GHcaliMagic, GHkoolBloom, GHphDown};
//Analong Pin Sensor Assignments - Analog Pins
//#define pH A0
//#define PPM A1
//#define waterTemp A2
#define lightA 22 //Relay 1/a - Relays[0]
#define lightB 23 //Relay 2/b - Relays[1]
#define pumpA 24 //Relay 3/c - Relays[2]
#define pumpB 25 //Relay 4/d - Relays[3]
#define ROpump 26 //Relay 5/e - Relays[4]
#define scrubberFan 27 //Relay 6/f - Relays[5]
#define heatVentA 28 //Relay 7/g - Relays[6]
#define heatVentB 29 //Relay 8/h - Relays[7]
int Relays[8] {lightA, lightB, pumpA, pumpB, ROpump, scrubberFan, heatVentA, heatVentB};
//Digital Pin Relay Assignments - 30 Series Pins - 120VAC~ switching
//#define 30 //2nd bank of 8 relays
//#define 31
//#define 32
//#define 33
//#define 34
//#define 35
//#define 36
//#define 37
//int Relays2[8] {30, 31, 32, 33, 34, 35, 36, 37};
//Digital Pin Valves[] array elements - 40 Series Pins - Hi/Lo Solenoid Valves
#define source 40 //waterValve[0]
#define upperProbes 41 //waterValve[1]
#define upperNuteRail 42 //waterValve[2]
#define siteReturnA 43 //waterValve[3]
#define siteReturnB 44 //waterValve[4]
#define lowerProbes 45 //waterValve[5]
#define lowerNuteRail 46 //waterValve[6]
#define betweenRails 47 //waterValve[7]
#define waste 48 //waterValve[8]
#define mainAccessA 49 //waterValve[9]
#define feedPlantA 50 //waterValve[10]
#define mainAccessB 51 //waterValve[11]
#define feedPlantB 52 //waterValve[12]
int Valves[13] {source, upperProbes, upperNuteRail, siteReturnA, siteReturnB, lowerProbes, lowerNuteRail, betweenRails, waste, mainAccessA, feedPlantA, mainAccessB, feedPlantB};
#define TURN_ON 0 // TURN_ON and TURN_OFF are defined to account for Active High relays
#define TURN_OFF 1 // Used to switch relay states for on/off of AC devices
RTC_DS1307 RTC;
float UTCOffset = -5.0; // Your timezone relative to UTC (http://en.wikipedia.org/wiki/UTC_offset)
char auth[] = "pasteAuthTokenFromEmailHere";
WidgetLCD lcdA(V2); //Set LCD widget to Advanced Mode - Widget to display project clock
DHT dhtA(A0, DHT22); // DHT instance named dhtA, I/O pin and sensor type
DHT dhtB(A1, DHT22); // DHT instance named dhtB, I/O pin and sensor type
SimpleTimer timer; // SimpleTimer instance named timer
//Serial2.begin() // For other baud rates
//Serial3.begin() // For other baud rates
Blynk.begin(auth);
dhtA.begin();
dhtB.begin();
Wire.begin();
RTC.begin();
RTC.adjust(DateTime(__DATE__, __TIME__));
//pinMode(nutePumps[8], INPUT_PULLUP);
//pinMode(Valves[13], INPUT_PULLUP);
pinMode(Relays[8], INPUT_PULLUP); //
pinMode(Relays[8], OUTPUT);
pinMode(nutePumps[8], OUTPUT);
pinMode(Valves[13], OUTPUT);
while (Blynk.connect() == false) {}
timer.setInterval(10000L, timeRoutine); // 10 second intervals between timed routiness
timer.setInterval(11100L, climateRoutine); // 11.1 second intervals between climate routines
//timer.setInterval(xxxxL, testResB);
//timer.setInterval(xxxxL, testResA);
delay(2500);
//Functions
void climateRoutine()
byte h1 = dhtA.readHumidity(); // f1 and h1 are fahrenheit and humidity readings
byte f1 = dhtA.readTemperature(true); // from DHT/A
byte h2 = dhtB.readHumidity(); // f2 and h2 are fahrenheit and humidity readings
byte f2 = dhtB.readTemperature(true); // from DHT/B
Blynk.virtualWrite(V0, f1); // Set Virtual Pin 0 frequency to PUSH in Blynk app
Blynk.virtualWrite(V1, h1); // Set Virtual Pin 1 frequency to PUSH in Blynk app
Blynk.virtualWrite(V3, f2); // Set Virtual Pin 2 frequency to PUSH in Blynk app
Blynk.virtualWrite(V4, h2); // Set Virtual Pin 3 frequency to PUSH in Blynk app
Serial.println(f1);
Serial.println(h1);
Serial.println(f2);
Serial.println(h2);
// Tests temp & humidity to see if preset values are exceed.
// If exceeded, a relay is trigger high to power an exhaust fan or heater.
//**************************** REMOVING HEAT *************************************//
if (f1 >= hiMaxTemp) //if "f1" is greater than or equal to hiMaxTemp,
digitalWrite(heatVentA, TURN_ON); // TURN_ON heatVentA (fan).
Serial.print("\t");
Serial.println(F("Exhausting the heat from A")); // Text printed to serial monitor
Serial.print("\t");
Serial.println();
else if (f1 <= lowMaxTemp) // or else if "f1" is less than or equal to lowMaxTemp
digitalWrite(heatVentA, TURN_OFF); // TURN_OFF relay E.
void timeRoutine()
DateTime now = RTC.now(); // reads time at beginning of loop
byte twelveHour = now.hour() - 12; // Variable used to display 13+ hours in 12 hour format
byte zeroHour = 12; // Variable use to convert "0" zero hour to display it as 12:00+
byte displayHour;
byte MIN = now.minute();
byte SEC = now.second();
char* meridian;
if (now.hour() == 0) // First we test if the hour reads "0"
displayHour = zeroHour;
meridian = "AM";
else if (now.hour() >= 13) // if no, Second we test if the hour reads "13 or more"
displayHour = twelveHour;
meridian = "PM";
displayHour = now.hour();
meridian = "AM";
char timeStamp[11];
char dateStamp[11];
sprintf(timeStamp, "%02d:%02d:%02d-%02s", displayHour, MIN, SEC, meridian);
sprintf(dateStamp, "%02d/%02d/%04d", now.month(), now.day(), now.year());
String ts;
String ds;
ts = timeStamp;
ds = dateStamp;
lcdA.clear(); //Advanced Mode
lcdA.print(3, 0, ts); //Advanced Mode
lcdA.print(3, 1, ds); //Advanced Mode
Serial.println(ts);
Serial.print(ds);
//*************** 12/12 BloomA Light - 6AM-6PM**********************************//
//***** Adjust hours and minutes in accordance with 24 hour time format. *******//
//***** Create tests where true is ON time and false is OFF time. *************//
boolean lightAstate = false;
if (now.hour() >= 6 && now.hour() <= 17) lightAstate = true;
if (lightAstate == true)
digitalWrite(lightA, TURN_ON);
Serial.print("\t");
Serial.print(F("Bloom A Light On")); // Text printed to serial monitor
Serial.print("\t");
Serial.println();
digitalWrite(lightA, TURN_OFF);
Serial.print("\t");
Serial.println(F("Bloom A Light OFf")); // Text printed to serial monitor
Serial.print("\t");
Serial.println();
//*************** 12/12 BloomB Light - 6PM-6AM**********************************//
//***** lightB is lit during the opposing 12 hours to lightA. *****************//
boolean lightBstate = false;
if (lightAstate == false) lightBstate = true;
if (lightBstate == true)
digitalWrite(lightB, TURN_ON);
Serial.print("\t");
Serial.print(F("Bloom B Light On")); // Text printed to serial monitor
Serial.print("\t");
Serial.println();
digitalWrite(lightB, TURN_OFF);
Serial.print("\t");
Serial.println(F("Bloom B Light OFf")); // Text printed to serial monitor
Serial.print("\t");
Serial.println();
//*********************************** FEED TIMEs - pumpA ******************************************//
// By testing hour once and minute twice, we isolate the "on" time and the duration it is "on". *****//
// If the Boolean becomes true, D32 is HIGH until Boolean becomes false again. **********************//
boolean pumpAstate = false;
if (now.hour() == 9 && now.minute() >= 0 && now.minute() < 10) pumpAstate = true; //9:00 am - 10mins
if (now.hour() == 15 && now.minute() >= 30 && now.minute() < 40) pumpAstate = true; //3:30 pm - 10mins
if (now.hour() == 22 && now.minute() >= 30 && now.minute() < 33) pumpAstate = true; //10:30pm - 03mins
if (pumpAstate == true)
digitalWrite(pumpA, TURN_ON);
Serial.print("\t");
Serial.println(F("Feeding PlantA")); // Text printed to serial monitor
Serial.print("\t");
Serial.println();
digitalWrite(pumpA, TURN_OFF);
//*******************************Feed Times - pumpB *******************************************//
boolean pumpBstate = false;
if (now.hour() == 9 && now.minute() >= 0 && now.minute() < 10) pumpBstate = true; //9:00 am - 10mins
if (now.hour() == 15 && now.minute() >= 30 && now.minute() < 40) pumpBstate = true; //3:30 pm - 10mins
if (now.hour() == 22 && now.minute() >= 30 && now.minute() < 33) pumpBstate = true; //10:30pm - 03mins
if (pumpBstate == true)
digitalWrite(pumpB, TURN_ON);
Serial.print("\t");
Serial.println(F("Feeding PlantB")); // Text printed to serial monitor
Serial.print("\t");
Serial.println();
digitalWrite(pumpB, TURN_OFF);
(like I am one to talk…
