Hello
I cant find a problem with my code. test Code from DHT Library works good, every read every second have values.
But in my code i have like 1 succesful over 50/100 reads.
Maybe someone have that problem or see some error in my code.
#include <FS.h>
#include <DHT.h>
#include <Wire.h>
#include "SSD1306.h"
#include <NTPClient.h>
#include <WiFiUdp.h>
#include "font.h"
#include <WiFiManager.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <ArduinoJson.h>
#define DHTTYPE DHT11
#define dht_dpin 2
DHT dht(dht_dpin, DHTTYPE);
char blynk_token[34] = "";
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "185.207.104.70", 3600, 60000);
SSD1306 display(0x3c, D3, D5);
void sendSensor()
String formattedDate;
String dayStamp;
String timeStamp;
timeClient.update();
formattedDate = timeClient.getFormattedDate();
int splitT = formattedDate.indexOf("T");
dayStamp = formattedDate.substring(0, splitT);
timeStamp = formattedDate.substring(splitT + 1, formattedDate.length() - 1);
Serial.println("day = " + String(dayStamp) + " and time = " + String(timeStamp));
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read DHT " + String(h) + " " + String(t));
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Serial.println("humidity = " + String(h) + "% and temperature = " + String(t) + "°C");
//display code removed
dht.begin();
delay(700);
//SPIFFS.format();
display.init();
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
strcpy(blynk_token, json["blynk_token"]);
Serial.println("failed to load json config");
Serial.println("failed to mount FS");
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 33);
WiFiManager wifiManager;
wifiManager.setSaveConfigCallback(saveConfigCallback);
wifiManager.addParameter(&custom_blynk_token);
//wifiManager.resetSettings();
if (!wifiManager.autoConnect("Monitor", "password")) {
Serial.println("WIFI connection failed");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
Serial.println("WIFI Connected");
strcpy(blynk_token, custom_blynk_token.getValue());
if (shouldSaveConfig) {
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["blynk_token"] = blynk_token;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.printTo(configFile);
configFile.close();
Blynk.config(blynk_token, IPAddress(139, 59, 206, 133), 8080);
//Blynk.begin(auth, ssid, pass, IPAddress(139,59,206,133), 8080);
bool result = Blynk.connect();
if (result != true)
Serial.println("Blynk connection faile");
Serial.println(blynk_token);
ESP.reset();
delay (5000);
Serial.println("Blynk connection succesful");
delay (5000);
timeClient.begin();
timeClient.setTimeOffset(7200);
