after I got my Wifly Board finally working, I figured our a new problem, BUT I was able to identify the source:
This is my setup void:
//++++++++++++++++++++++++++++++++++++++++++++++PCA9685+++++++++++++++++++++++++++++++++++++++++++++
for (int i=0; i<5; i++) {
boards[i].begin();
boards[i].setPWMFreq(800);
if (i<4) {
for (int j=0;j<13;j++) {
boards[i].setPWM(LEDpins[j], 0, 0);
else if (i==4) {
for (int k=0;k<8;k++) {
boards[i].setPWM(LEDpins[k], 0, 0);
//uint8_t twbrbackup = TWBR;
//TWBR = 12;
//Serial.begin(9600); // Set console baud rate
//delay(10);
WiFlySerial.begin(9600); // Set your RN-XV baud rate
if (!wifly.begin(&WiFlySerial)) {
BLYNK_FATAL("Failed to start wifly");
//wifly.setBaud(9600);
//WiFlySerial.begin(9600);
Blynk.begin(auth, wifly, "tnthome", "testtest");
timer.setInterval(2000, blinking);
//++++++++++++++++++++++++++++++++++++++++++++++RTC++++++++++++++++++++++++++++++++++++++++++++++
rtc.begin();
//rtc.setTime(21,00, 00);
pinMode(4, OUTPUT);
These are the libraries I use:
#include <WiFlyHQ.h>
#include <BlynkSimpleWiFly.h>
char auth[] = "ac5639ce971f46d4a9b990c28cbdf4a2";
#define WiFlySerial Serial1
boolean autoLED=true;
WiFly wifly;
#include <DS3231.h>
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
#include <DS18B20.h>
So the problem is that my code stucks at rtc.begin();
and doesnt start the void loop.
If I comment that out, everything worx fine.
Now the weird thing:
Onboard of my PCB are:
- DS3231
- Atmega 1284
- Wifly Board
If i fire this with 5v and Gnd, everything worx fine, even if rtc.begin is not commented out.
If I connect the board to my LED PCB (with PCA9685 on board), it only worx if I comment it out.
Connection is 5v, gnd, SDA, SCL.
So of course both, PCA9685 nd RTC use I2C.
So you guys you think you can help me out?
That is the RTC library: http://www.rinkydinkelectronics.com/library.php?id=73
