Blynk library 0.6.1
Android
Arduino
Previously I tried to successfully connect it even can be controlled from Android to Arduino.
Before the last error I did was Arduino using the battery, when I re-uploaded via the laptop something happened.
Then I tried removing blynk.begin, it succeeded to run the program.
scheme:
I use Bluetooth connected to a laptop, then use a virtual serial port, run local server and client to connect COM from Bluetooth to local server. Controlled by Android from WiFi.
I use the scheme to fulfill my college assignments. thanks.
char auth[] = "W9KxUhtSLkGGAyxYmiDImNjGC0DKiKmF";
Blynk.begin(auth, Serial);
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
delay(3000);
digitalWrite(13, LOW);
delay(3000);
