Hi, I want to use the timers section in blynk automation, but I have a problem.
1- The saved automation is executed only once. I want the automation to run whenever the condition is set, but it only runs once.((It was not possible to run one automation in a row.))
2- After refreshing the site, the When commands in the automation section will be deleted
Please watch the movie, you will definitely notice
You see that. The data will be deleted after refreshing the site. Not visible to you?
And you see. Only the first time the automation command is executed correctly. Is this not visible to you?
I tested several times and encountered the same problem
The information is deleted after refreshing the site. And the stored automations are not repeated one after the other
UI bug. It is fixed already. Will be available soon.
That’s by design, automation is triggered only once when the condition is changed to avoid “spamming”. Or it could be limit period - Automations - Blynk Documentation
I’m trying to set a timer.
After activating the first switch, turn on both switches for 5 seconds and then turn off both switches.
This works fine but does not run back and forth. Once run, it will no longer run. This automation can be used again in a few minutes, as if there is a time limit
