Hello everybody,
I am using an arduino MKR 1010 to turn a LED on and off based on a timer using Blynk local server. As you can see in the code below first I sync the time and then turn the a digitale output low or high depending on the time.
#include <SPI.h>;
#include <WiFiNINA.h>;
#include <BlynkSimpleWiFiNINA.h>;
#include <TimeLib.h>;
#include <WidgetRTC.h>;
char auth[] = "xxxx";
char ssid[] = "xxxx";
char pass[] = "xxxx";
WidgetRTC rtc;
BLYNK_CONNECTED() {
rtc.begin();
BLYNK_WRITE(V5)
Serial.print("Got a value: ");
Serial.println(param.asStr());
if (String(param.asStr())=="1.0")
{ digitalWrite(6,HIGH);
{ digitalWrite(6,LOW);
pinMode(6,OUTPUT);
Blynk.begin(auth, ssid, pass, IPAddress(192,168,0,101), 8080);
If I use the same code on the Blynk cloud server it works. For the local server I only add:
BLYNK_CONNECTED() {
rtc.begin();
to update the local time. Why does this code work on the Blynk cloud server and not on the local server?
Thanks in advance,
Bart
