Hello blynkers,
I’m stuck with my project so I need your help.
I’m trying to control my pellet stove with arduino mega 2560. At the beginning I connected my computer with stove’s serial interface and perform plenty of tests and I find out what I should send over serial to the stove, and what stove send me back. When I send 2 bytes, stove responds with 2 bytes. I don’t need first byte from the respond, only second.
Serial0 on the mega is used for serial monitor, Serial1 is used for communication.
Baudrate: 1200
Data bits: 8
Parity: None
Stop bits: 2
If I send same 2 byte command every 5 seconds, stove should always respond with same 2 bytes, but for some reason, I’m not able to read responds correctly. Forst couple of cycles I’m getting correct values, and than something goes wrong, and responds mess up. After 20-30 cycles single correct value is recieved again, but I have to find reliable solution for reading second byte from the respond. Can you take a look to my code? Project is much complex but I tried to simplified it just for serial reading issue demonstration. Firstly I tried to read serial in loop but then I saw in documentation that blynk doesn’t like that so I modified loop to be 2 lines only, and add timer… What else I can try? Thanks in advance.
#include <Ethernet.h>
char auth[] = "xxx";
//Serial for serial monitor
Serial.begin(1200, SERIAL_8N2);
//Serial1 for communication with stove
Serial1.begin(1200, SERIAL_8N2);
Blynk.begin(auth);
// execute refreshWidget every 5 seconds
timer.setInterval(5000L, refreshWidget);
void refreshWidget(){
//executing readFunction with 2 bytes as parameters return one int
int valueWidget = readFunction(0x00, 0x21);
Blynk.virtualWrite(V10, valueWidget);
Serial.print("Second received byte is ");
Serial.println(valueWidget, HEX);
int readFunction(byte firstByte, byte secondByte) //
//array of 2 bytes need to be sent over serial
byte readCommand[] = {firstByte, secondByte};
Serial1.write(readCommand, sizeof(readCommand));
//stove responds also sending back 2 bytes
byte stoveRespond[2];
// read data only when you receive 2 bytes:
if (Serial1.available() >= 2) {
for (int i=0; i<2; i++) {
stoveRespond[i] = Serial1.read();
//return only second received byte as int
return (int)stoveRespond[1];
