Hi at all.
I have make an project with arduino mega,ethernet shield and ssr…
on my phone (ios) i have a pulse to run a relay and a led…
when i press a virtual input on iphone,the program on arduino run a solid state relay and run a led on my phone…
the pulse on phone,when i have press it,change ,and the round of button is full color,
all run very well,without problem…my version of blynk is 2.26.5
Im insert same user and same password on phone of my wife,it not run,she have android…
the skin are same,same position of led,button and other,same settings…
but the system not run,
with she phone,when im press a button,the led light,the relay run,but when im depress a button nothing turn off…it turn off only when im press another one the button…om not undestand why…
is possible for comunity help me ??
im test change version,from last at 2.25.7 or 2.25.3 but not change nothing…
sorry for bad english and best regards
Not without a proper description of the problem, full details of the widgets in the app and which pins (virtual or digital) they are connected to and the code running on your Arduino.
Hi , I’m use one virtual pin v5 as a button (pulse) one led (v101) solid relay is connected at digital output 45 of arduino mega
No more connections…
But I’m sure if the system work , I’m start with this configurations and after add other 11 output , othe pulse and switch, one potentiometer … the system I’m sure 100% if work perfectly , without bug or error…
My problem is this…
My system make and test with iPhone … and test if for more days ,
I’m not undestand why , I’m login on my account blynk with another mobile phone , I’m look same situation ( position of switch, led and other , label on that … all same ) but , if I’m press swithc for run a relay with iPhone , the switch change situation on “pressed” change name , relay run perfectly , and arduino talk at blynk to light a led , and when I’m depress the switch all turn off ( correct situation) if I’m make same operation, when depress switch , it run ( o iPhone not ) in same moments , same situation same time , with two mobile on table … is a difference from iPhone app and android app ?? Is a version ?? From 2.25.5 to 2.25.3 or 2.25.7 ?? I’m not undestand that … the program on arduino ( other 1500 li e ) I’m not think is possible insert here all
But is on old pc without connection of internet , and now I’m write wit my phone ,and but the problem I’m super sure is not on arduino sketch , I’m think is or for version of app , or other combination of situation … I’m look one not important difference for two version( iOS or Android) when I’m open the setting of switch , the label on and off are invert position , iOS have on at left and android right , I’m think is other
