Hello.
Im having some issues migrating to the new Blynk plattaform.
When I add this…
#define BLYNK_TEMPLATE_ID "TMPL4cytDW11" //not real values
#define BLYNK_DEVICE_NAME "TemplatePrueba"
#define BLYNK_AUTH_TOKEN "w3K-7Bo47IB0yaeYaNOXIaEtKjgm8-11" //not real values
…to the code, the board keeps rebooting, with this info on the Sertial monitor:
> [51] Connecting to TucoWifi
> [2554] Connected to WiFi
> [2554] IP: 192.168.0.78
> [2554]
> ___ __ __
> / _ )/ /_ _____ / /__
> / _ / / // / _ \/ '_/
> /____/_/\_, /_//_/_/\_\
> /___/ v1.1.0 on ESP8266
> #StandWithUkraine https://bit.ly/swua
> [2564] Connecting to blynk.cloud:80
> [5776]
> ets Jan 8 2013,rst cause:4, boot mode:(3,6)
> wdt reset
> load 0x4010f000, len 1384, room 16
> tail 8
> chksum 0x2d
> csum 0x2d
> v614f7c32
> ~ld
> [48] Connecting to TucoWifi
> [2551] Connected to WiFi
> [2551] IP: 192.168.0.78
> [2551]
I’ve reduced the code to the bare minimun (see below), to switch between the old blynk and the new one.
With the old bynk, the board works ok and can connect to the old app.
When I add the lines to connect with the new blynk, it connects, but keeps rebooting forever with rst cause:4, boot mode:(3,6)
What can be the problem??
Thank you very much.
//for NEW BLYNK
//char auth[] = BLYNK_AUTH_TOKEN; //for new Blynk
char auth[] = "3460ae1237bc48afbd305fea68f88011"; //For OLD Blynk
char ssid[] = "TucoWifi";
char pass[] = "VIVAPEZ88";
