Please edit your post and add triple backticks at the beginning and end of your code so that it displays correctly.
Copy the triple backticks from my post.
Click the pencil icon at the bottom of your first post.
After the line that says ”i have same issue to” insert a blank line and paste the triple backicks on to it.
Scroll down to the bottom of your code and insert a blank line then post the triple backticks onto this line as well.
Save your edit.
I’m also unsure why he’s doing WiFi.begin, then using Blynk.begin rather than Blynk.connect, but clearly nothing to do with the original topic, so I’ve moved it to a new topic.
Once again, you’ve used the wrong characters to format your code, so it has been removed.
The difference between how correctly formatted code looks in your post compared to unformatted code is fairly obvious, so when you you look at the preview, or after you’ve hit the Post/Reply button, you should look to see if you’ve done it correctly.
If you can’t find the correct key on your keyboard then just copy’paste the characters that I’ve previously provided for you.
So what is the difference between this code and your previous code?
You’re still doing the WiFi.begin stuff, which is unnecessary with Blynk.begin, and your screenshot of the serial monitor tells only half the story (copying and pasting, using triple backticks again, is much better than screenshots.
BTW, the triple backticks need to be on a line of their own to work correctly, otherwise you lose the first line of code.
