My Project for Teacher is to show the Temp and Humidity via NodeMCU+DHT11+Blynk
but I try every code in the two topic below, it’s does work because the code is error
can you help me by the code or the process of it
please, my project is in due time now please help me
The example you posted where for the arduino uno using the ESP as a shield only. I assume you want the ESP as a standalone.
I’m using ESP8266 standalone with an DHT11. You need to adapt the following parts:
DHTPIN - the pin, where the data-port of your DHT is connected
auth-key
wifi settings
Blynk should receive data on the virtual ports 4 and 5.
#include "DHT.h"
#define DHTPIN 4 // The pin you connect to
#define DHTTYPE DHT11 // DHT 11 Change this if you have a DHT22
DHT dht(DHTPIN, DHTTYPE,16); // Change this to
char auth[] = "Your Auth";
Blynk.begin(auth, "XXXX", "XXXX");
timer.setInterval(2000, sendDHT);
void sendDHT()
//Read the Temp and Humidity from DHT
float h = dht.readHumidity();
int hum = (int) h;
int tem = (int) t;
//Write values to V04 and V05
Blynk.virtualWrite(4, hum);
Blynk.virtualWrite(5, tem);
hey Mr.Minc , thank for your help again
but the problem is on the blynk it’s show the result " 2.147 " both v4 and v5 virtual
I don’t know why is it
the code that I use is
#include "DHT.h"
#define DHTPIN 2 // The pin you connect to
char auth[] = "279950f911cb4fb1b957a272a9a17124";
Blynk.begin(auth, "myID", "myPaSSword");
void sendDHT()
int hum = (int) h;
int tem = (int) t;
did I miss something or
can you tell me the process
I’ve just uploaded the code once more and it does work. However I can replicate your error when connecting the sensor data pin to the wrong GPIO. In your code you stated that you use GPIO 2. Make sure, that the data-pin is really in GPIO 2.
I get 21474 as values for both virtual pins when declaring to use pin 2 but connect to pin 4 or 5.
