Prevent Blynk from writing a digital Pin wich was not designed in the App
Hi there and hello Blynk community!
i use Blynk with Virtual Pins V01 V02 etc. for App communication.
depending on the input, i wish to close a relais, turn on a lamp, etc.
I can choose wich Pins the App user can see and control, but…
How to prevent the app user from directly running https://server.tld:9443/authkey/update/D06?value=1
Since the user’s got the QR code containing server, port and authkey he can change any Pin
even if not designed in the App
is there a way to prevent that?
Greetings
Adding this line, preferably at the top of your sketch, should achieve that…
#define BLYNK_NO_BUILTIN   // Disable built-in analog & digital pin operations
Wow that was quick! i will test it!
Thanks a bunch!
it cannot be further defined in detail?
Greetings
As far as I’m aware, that’s it. What more were you looking for?
