Im trying to sync a potentiometer with the slider widget. I figured out how to sync a button with a widget button but i can’t seen to figure this out.
Can anyone point me in the right direction ?
Blynk.virtualWrite(slider, analogRead(potPin));
When not being more specific that should do it
Unfortunately, short of motorizing the pot (something like how a Servo works, but without the hold position tendencies), then every time you adjust the slider, it will readjust back to the potentiometer position… so it really becomes a one way sync… or more precisely, just an position indicator for the potentiometer, and a Level or Graph Widget would work just as well in that case.
I just figured this out 10 seconds ago when i finished my code with the use of an old post of yours
int potPin= A0; //Declare potPin to be analog pin A0
int LEDPin= D4; // Declare LEDPin to be arduino pin 9
int readValue; // Use this variable to read Potentiometer
int writeValue; // Use this variable for writing to LED
int brightness = 0; // Start off with LED off
Serial.begin(9600); // turn on Serial Port
pinMode(potPin, INPUT); //set potPin to be an input
pinMode(LEDPin, OUTPUT); //set LEDPin to be an OUTPUT
BLYNK_WRITE(V1) // Slider widget function, runs everytime slider is adjusted.
brightness = param.asInt(); // Get slider value.
analogWrite(LEDPin, brightness); //Send data to LED
void Potentiometer()
readValue = analogRead(potPin); //Read data of Potentiometer
brightness = (255./1023.) * readValue; //Calculate Write Value for LED
Blynk.virtualWrite(V1, brightness); //Send feedback to slider Widget
Potentiometer();
I might switch to buttons in stead or i should try to figure out how to make Blynk ignore potentiometer input when the slider is being adjusted.
Some form of comparator flag? Give the slider priority of movement and only readjust if pot moves from last pre-slider adjustment position.
I guess that should work. I’ll try it out
This is where i got so far now its just a matter of resyncing the slider and the potentiometer without looping the whole thing.
int potValue ;
potValue = analogRead(potPin);
BLYNK_WRITE(V1) // Slider to led
void Potentiometer() // Potentiometer to led
if(potValue != readValue){
//Blynk.virtualWrite(V1, brightness); //Send feedback to slider Widget
delay(300);
Potentiometer();
